d series: thermostat housing is it threaded?
Old Feb 10, 2007 | 03:57 PM
allsho's Avatar
Default d series: thermostat housing is it threaded?
As asked, is the housing threaded? or is it just where the bolts go in from the housing threaded?
Old Feb 10, 2007 | 04:05 PM
1.6civicturbo's Avatar
Default Re: d series: thermostat housing is it threaded? (allsho)
Just the bolts are theaded, but some times u get corosion in the housing hole and it gives u the look of the haousinf being threaded but its not not if u are concerned just clean the hole before u put the bolts back
Old Feb 10, 2007 | 04:15 PM
allsho's Avatar
Well, see here is why I ask.
I used the wrong bolt on the "housing outlet" part, and I snapped the head off of it. The bolt closest to the motor.
Now, if I take out the other bolt from the side furthest from the motor, will the housing just slip off? and then i can use plyers and slowly get that other bolt with the head broken off, out.
Old Feb 10, 2007 | 04:17 PM
allsho's Avatar
thats why i need to know if that outlet is threaded, because then i am screwed and i need to drill it out
Old Feb 10, 2007 | 04:36 PM
Sikocivic's Avatar
Default Re: (allsho)
You are correct. Just take the other bolt off and it will come right off, wel it will after you work at it foe awhile. They are always stuck.
Old Feb 10, 2007 | 04:41 PM
allsho's Avatar
Default Re: (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">You are correct. Just take the other bolt off and it will come right off, wel it will after you work at it foe awhile. They are always stuck. </TD></TR></TABLE>
As long as you're sure, then I must say "I Love you" for posting this.
It's dark here, I dont have a garage and it's cold (-35) sooo going and looking wasnt do-able right now. Thanks again!
tpot90
Apr 5, 2008 09:46 AM
spidermancivic
Aug 11, 2007 08:17 AM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
BlueSi2k
Mar 31, 2004 01:56 PM
RuthlessEF-9
Jun 26, 2003 05:24 AM
