valve tapping wtf
Old Feb 10, 2007 | 01:52 PM
raphael's Avatar
Default valve tapping wtf
i regauged my valve to factory spec on my d16y8. and the ***** is still ticking any i dea on how much tighter i can go without riskin a misfire? or any solutions?
Old Feb 10, 2007 | 01:53 PM
dr_latino999's Avatar
Default Re: valve tapping wtf (raphael)
Positive it's your valves that are tapping and not your injectors? I can hear my injectors from 30 paces with the hood open
Old Feb 10, 2007 | 02:06 PM
YoungKadafi's Avatar
also do you have a header? that will increase the sound if its an ebay one
Old Feb 10, 2007 | 02:07 PM
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">also do you have a header? that will increase the sound if its an ebay one</TD></TR></TABLE> As opposed to a header from say...SMSP?
Old Feb 10, 2007 | 02:08 PM
opposed to OEM
Old Feb 10, 2007 | 02:10 PM
allricedout's Avatar
its normal
Old Feb 10, 2007 | 02:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">opposed to OEM</TD></TR></TABLE> Touche
Old Feb 11, 2007 | 02:51 PM
raphael's Avatar
Default Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">its normal</TD></TR></TABLE>na i dont thick that its normal. a gas engine shouldnt sound like a diesel. anywayz whats the max distance i can tighten my valve to without causing a misfire??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">also do you have a header? that will increase the sound if its an ebay one</TD></TR></TABLE>no i dont it stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Positive it's your valves that are tapping and not your injectors? I can hear my injectors from 30 paces with the hood open </TD></TR></TABLE>my injectors tapping? how can they possibly be making that noise? anywayz i no its not because i tightend all of them with no clearancejust to make sure and there was no noise at all so i know its the valve
Old Feb 11, 2007 | 03:00 PM
Default Re: (raphael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">can they possibly be making that noise? </TD></TR></TABLE> Well it is an electronically controlled valve that opens and closes a whole mess of times (more than you can count) during it's life span, so over the years they get "loud".
Old Feb 11, 2007 | 03:08 PM
EG2Driver's Avatar
Default Re: (dr_latino999)
Check the LMAs. Press down on the rocker arm underneath the VTEC lobe. If it sicks, thats why your valves are loud.
Old Feb 11, 2007 | 03:23 PM
raphael's Avatar
Default Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">Check the LMAs. Press down on the rocker arm underneath the VTEC lobe. If it sicks, thats why your valves are loud.</TD></TR></TABLE>did u mean sicks or "sticks". and if it does stick how can that be adjusted
Old Feb 11, 2007 | 04:05 PM
EG2Driver's Avatar
sorry i meant if it sticks. If it sticks, the LMAs are on their way out and should be replaced.
Greg50Lt
Honda Civic (2006 - 2015)
12
Sep 21, 2007 06:13 PM
1fastEK9
Aug 10, 2007 02:44 AM
P_t0wn
May 11, 2006 12:11 PM
JeremyL
15
Feb 12, 2005 03:08 PM
SleepnCiViC
Feb 14, 2004 01:49 AM
