I need help removing trim on the rear hatch....
Old Feb 10, 2007 | 09:36 AM
crazycaucazian86's Avatar
Default I need help removing trim on the rear hatch....
Anyone have a DIY or a link to help me remove the trim on the rear hatch of my hatchback? I'm trying to wire a rear view camera and need to pop the panels off and wire it.
Old Feb 10, 2007 | 10:48 AM
tha_badguy's Avatar
just look at em...
it should be self explanatory
if u dont see any visible screws holdin em on
then there clipped in
Old Feb 25, 2007 | 04:00 PM
NOFX's Avatar
H-T White Ops
Two clips at the bottom under the latch. Apparently you're supposed to press the middles in while you pull the outer section out. I managed to just pull though and broke both of mine. $2.59 apiece to go spend at Honda.
The rest on that inner panel are clips behind the panel. Pull the entire panel away to remove those clips.
By the way, if anyone can help me to figure out how to completely remove the last grey clip (shown in this pic) that is stuck in the car, that would be very helpful. The section of the clip sticking out is very flexible and my clip puller just lets it slip out. The other side, while difficult to get to with pliers, is much tougher and i can't pinch it enough to remove.
Here are all the clip locations to help anyone else though.
VX
32
Apr 11, 2013 05:27 PM
acmoc
Apr 5, 2010 09:21 AM
vrenlos
Nov 11, 2008 07:00 PM
ecovillain
Dec 20, 2004 11:50 PM
