ABS light on 00 GSR
Old Feb 10, 2007 | 08:59 AM
ac_attak's Avatar
Default ABS light on 00 GSR
Hey, i have an abs light on for the rear left wheel sensor. Turns out the caliper there was seized up and the sensor was full of brake dust so i figure that is why the light is on. I got everything fixed up there now but the light is still on. Does the code need to be cleared for it to stop coming on? and if so how do i clear it?
It is a 2000 model. When i searched i could only find info on how to clear the abs codes from earlier model integras.
Old Feb 10, 2007 | 09:15 AM
ac_attak's Avatar
Default Re: ABS light on 00 GSR (ac_attak)
Nevermind i just found the info. I'll just post it for future searching references anyway.
For the 1998 and up model you need to with the jumper wire still installed and the ignition off, press on the brake pedal and then turn the ignition on. When the ABS indicator light goes out, release the brake pedal until the light comes on again and press on the brake pedal. Hold the pedal down until the indicator light goes out and release the pedal. The indicator light should blink twice to indicate that the codes are erased. Turn off the ignition, remove the jumper wire and plug in the service check connector.
Old Feb 10, 2007 | 09:45 AM
ac_attak's Avatar
Ok i did it and after the abs light blinks twice to indicate the codes have been cleared, it comes right back on again. So i guess i need to replace that sensor?
Old Feb 10, 2007 | 11:18 AM
in10ceCiviC's Avatar
my ABS jus started going on in my car ..(92 GSR) i cleaned the sensor and its still on , i got full brake fluid and its still on .......i think its my sensor thats faulty
probally same problem w/ your car ...
Old Feb 10, 2007 | 11:27 AM
ac_attak's Avatar
Yeah i was checking ebay and most sellers are selling good working order abs sensors for under $20, so thats not bad at all. The one i need is not on there though
Old Feb 10, 2007 | 11:38 AM
Dogginator's Avatar
Daisy... Daisy...
Check the impedance of the LR wheel sensor. That will tell you if it is bad. You can find the spec in the Helm manual. (I recall that it should be about 900ohms.) Search google for "hondahookup manuals" if you do not have one.
Old Feb 11, 2007 | 02:49 PM
ac_attak's Avatar
Does anybody know if the abs sensor off a 94 ls will work on my gsr? Or even link me to a site where i can compare the part numbers for the integra?
Old Feb 11, 2007 | 04:46 PM
Dogginator's Avatar
Daisy... Daisy...
It will work. You can check part numbers here:
http://www.acuraparts247.com
For some reason, Honda changed the part number only for the LR wheel sensor. The RR sensor is the same, so the LR should be compatable.
When I replaced my LR sensor on my 97 GSR, I bought a new sensor. It was kind of a pain in the butt to change because my LCA bolts were seized. Unless you are getting the used sensor cheap, you should consider that it may fail sooner than a new one.
Old Feb 12, 2007 | 04:45 PM
ac_attak's Avatar
Default Re: ABS light on 00 GSR (Dogginator)
How much did you pay for a new sensor?
Old Feb 12, 2007 | 04:49 PM
Dogginator's Avatar
Daisy... Daisy...
I think it was $105. I purchased it from hondaautomotiveparts.com, as they had the cheapest price that I could find. It would be nice if just the end of the sensor could be replaced, but the sensor was much shielding and mounting points on it to fit the suspension.
fotoforce
Aug 21, 2018 03:56 AM
DC-2guy
Jun 25, 2009 11:23 PM
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
faiz_23
May 26, 2002 08:22 PM
