how to identify a itr head
Old Feb 10, 2007 | 01:14 AM
moz92's Avatar
Default how to identify a itr head
i know its been posted here a while back but i had doubts on the green paint behind the distributor thing. people say if the head has green paint behind the distributor thats the best way to identify if it is really a itr head. i was thinking any body can put green paint there and sell it to me and rip me off. sorry guys but im going crazy cuz im buying a c5 and i dont want get ripped off.
any advice will greatly be appreciated and would help me sleep better
Old Feb 10, 2007 | 01:30 AM
Kafelatte's Avatar
Default Re: how to identify a itr head (moz92)
on the front of the head at the top of the exhaust port there are 3 stamping.don't remember the order but if it's a itr head it should have a p73 stamping on one of them.
Old Feb 10, 2007 | 01:34 AM
BlueIntegraBoy's Avatar
Default Re: how to identify a itr head (kay20adc2)
B16 and B17 heads also have the same casting number, which is PR3-X (X = 1,2,3,4). Other than the green paint, I'm not too sure.
Old Feb 10, 2007 | 05:50 AM
egsir2's Avatar
PR3 reffers to b16 and b17 heads. he wants to know how to identify a b18c5 head...which is P73.
Old Feb 10, 2007 | 05:54 AM
TypeRobert's Avatar
Default Re: (egsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsir2 &raquo;</TD></TR><TR><TD CLASS="quote">PR3 reffers to b16 and b17 heads. he wants to know how to identify a b18c5 head...which is P73.
If he rules out that the one hes looking at is not a b17/b16 head then hes left with a itr head because it definetly isnt a gsr.
Old Feb 10, 2007 | 06:11 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsir2 &raquo;</TD></TR><TR><TD CLASS="quote">PR3 reffers to b16 and b17 heads. he wants to know how to identify a b18c5 head...which is P73.</TD></TR></TABLE>
No, a C5 head will be stamped PR3, just like a B16.
Old Feb 10, 2007 | 06:13 AM
egsir2's Avatar
Default Re: (TypeRobert)
i still dont get it. if your looking for a way of identifying a certain head....why would you want info on a completely differnet head. doesnt make sense to me. if your looking for an ITR Head,look for P73 stamp...end of story.
Old Feb 10, 2007 | 06:15 AM
egsir2's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">No, a C5 head will be stamped PR3, just like a B16. </TD></TR></TABLE>
you 100% sure on that? will USDM and JDM be different. my experiences will be wilth JDM only.
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsir2 &raquo;</TD></TR><TR><TD CLASS="quote">i still dont get it. if your looking for a way of identifying a certain head....why would you want info on a completely differnet head. doesnt make sense to me. if your looking for an ITR Head,look for P73 stamp...end of story.</TD></TR></TABLE>
No, it's not "end of story", and I don't see why you're having trouble grasping this concept. A B18C5 head will be stamped PR3, just like a B16 head. You <u>can't</u> determine whether or not a head is from a B18C5 by simply looking at the stamp.
Old Feb 10, 2007 | 06:18 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsir2 &raquo;</TD></TR><TR><TD CLASS="quote">you 100% sure on that? will USDM and JDM be different. my experiences will be wilth JDM only.</TD></TR></TABLE>
USDM and JDM ITR heads are both PR3.
Old Feb 10, 2007 | 06:21 AM
egsir2's Avatar
then, my most humble of apologies. i stand corrected.
Old Feb 10, 2007 | 06:28 AM
Padawan's Avatar
Darth ModerVader
Moz92, identifying an ITR head can be somewhat difficult, but some things to look for include:
- the green paint you already mentioned
- paint on the valvesprings (yellow intake, blue exhaust)
- the relatively mild factory port work
- if the head is complete, the ITR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsir2 &raquo;</TD></TR><TR><TD CLASS="quote">then, my most humble of apologies. i stand corrected.</TD></TR></TABLE>
We're all here to share information and learn.
Old Feb 10, 2007 | 11:22 AM
moz92's Avatar
Default Re: how to identify a itr head (Padawan)
will the actual camshafts have a number stamped on them?
Old Feb 10, 2007 | 12:02 PM
Padawan's Avatar
Darth ModerVader
Old Feb 10, 2007 | 01:51 PM
moz92's Avatar
thanx for the pics.
Old Feb 10, 2007 | 02:23 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
How would you determine a gsr or b16 cam from those cams pitured? I always thought they had to be measured.
Old Feb 10, 2007 | 03:37 PM
NJcoupe's Avatar
Default Re: (THE GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.technet.ff-squad.net &raquo;</TD></TR><TR><TD CLASS="quote">
Note:
• The 89-91 B16A cam lobe profiles are the weakest of the bunch. All of them are weaker - whether you have a 1-series or 5-series 89-91 B16A engine. If you can get a set of newer cams, I highly advise it.
• A majority of the 92+ B16A/B17A and 94+ B18C (JDM +US) cam profiles are pretty much the same. Although, the 94+ B18C cams seem to put out a bit more power....just a little bit. Dyno-testing is the best way to tell between these stock cams. Again, 'R' cams are best to have over these....
• Your best bet over any of the stock cams is to purchase a set of 'R' cams. Those blow away any of the stock cams - about 7hp on an naturally aspirated VTEC engine. Of course, if you want more cam power, try Spoon or Toda. Just make sure you get the proper valvetrain to work with those bigger cams or else you can end up with damaged valvetrain components!
Old Feb 10, 2007 | 03:56 PM
THE GUY's Avatar
Thanks. This will deff. come in handy.
Old Feb 10, 2007 | 04:14 PM
Teknoshaman's Avatar
* B A N N E D *
Look for the badge on the side.
LoLz!
Old Feb 10, 2007 | 06:55 PM
MiamiEJ1's Avatar
Default Re: (Teknoshaman)
USDM and JDM ITR heads are both PR3. </TD></TR></TABLE>
100% Correct. Green Paint FTW
Old Feb 10, 2007 | 07:15 PM
blaze the chemi's Avatar
You could also ask the guys in the ITR forum. I would certainly hope they'd know. I could've sworn though that the USDM type R head had a p73 stamp. I know the B16(a) and B18(r) heads are almost identical w/ the later having minor port jobs.
&lt;just searched&gt;
http://www.hondamarketplace.co...84914
^^^looks good to me. Another wrinkle in the brain for me haha
boosted.si04
Mar 28, 2010 12:26 PM
TurboEM1
Dec 26, 2009 07:50 PM
slimjimming6688
Dec 6, 2008 12:54 AM
pcp 914
Dec 20, 2005 11:57 PM
type r 01-1063
May 29, 2002 10:20 AM
