failed smog test
Old Feb 9, 2007 | 08:32 PM
noss88's Avatar
Default failed smog test
my civic failed smog test and i was wondering what should i check...
92 civic si
d16z6 with greddy turbo
greddy turbo bov
everything else is stock
thx in advance
pmed hazw8st, hope he can help me
Modified by noss88 at 9:56 PM 2/9/2007
Old Feb 10, 2007 | 12:58 AM
KnightX's Avatar
Default Re: failed smog test (noss88)
any shop should know that a aftermarket turbo car will not even pass e-test... if they still went ahead and did it for u then they r just tryin to take ur money...
Old Feb 10, 2007 | 07:27 AM
thesmogman's Avatar
Default Re: failed smog test (KnightX)
Now wait just a second. There are C.A.R.B. legal turbos that should pass the E-tests. The California Air Resources Board tests them to see if they do increase emissions, if they don't then they are assigned a CARB# and are very legal. Even in California.
What I would do is find one that is legal and uses the greddy turbo and try to match that set-up. As in timing and boost pressure etc...
Old Feb 10, 2007 | 08:09 AM
KLiK's Avatar
and if that doesn't work:
most likely that the catalytic converter is not enough for the D16turbo (it is for the D16 NA)...so try to put a bigger one, for some 2,0 engine Honda has got...
Old Feb 10, 2007 | 09:23 AM
h22apwrdcivic's Avatar
try this stuff with a half a tank of gas, run it 30min-1hr before hitting the emissions station. it will lower your emissions and cleans same time.
Old Feb 10, 2007 | 09:30 AM
BUNNYz's Avatar
can you post the # where you failed? then we can start from there.
Old Feb 11, 2007 | 11:51 AM
bonestock91's Avatar
if u have a turbo, then u kew when u put it in that u werent going to pass smog. that why if ur going to do **** like that, u gotta know ppl in da smog bidness.
Old Feb 11, 2007 | 02:30 PM
jay_cue's Avatar
Default Re: (bonestock91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonestock91 &raquo;</TD></TR><TR><TD CLASS="quote">if u have a turbo, then u kew when u put it in that u werent going to pass smog. that why if ur going to do **** like that, u gotta know ppl in da smog bidness. </TD></TR></TABLE>
you can pass smog with the turbo. he just has to make sure everything is running right. right air/fuel mix, cat working. its a smog legal turbo. so it can pass legally.
LAOS
Sep 4, 2005 10:28 AM
SPOONup
Jan 7, 2005 01:25 PM
is3oo
Aug 27, 2004 12:36 AM
L4NDO
May 1, 2002 02:28 AM
2k2civic
Jan 16, 2002 12:29 PM
