second counter shaft broke?
Old Feb 9, 2007 | 06:48 PM
ALL IMPORT's Avatar
Default second counter shaft broke?
well just broke 2 teeth of my counter shaft in my gsr trans. didint hurt anything else just like the first time. bit i cant figure out how did this happen twice u would think someting else would break for a change.
anyone have a issue or a idea what is causing this besides power.
1st time was at the track 2nd was on the street
Old Feb 10, 2007 | 03:52 AM
DaveF's Avatar
Default Re: second counter shaft broke? (ALL IMPORT)
shocking the transmission "upon take off" or on gear changes. also, if you dont have the shafts shimmed properly, they might actually get binded up when you clip the counter into the case, and that would "help" break it.
Old Feb 10, 2007 | 05:22 AM
Antilag's Avatar
Default Re: second counter shaft broke? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">shocking the transmission "upon take off" or on gear changes. also, if you dont have the shafts shimmed properly, they might actually get binded up when you clip the counter into the case, and that would "help" break it. </TD></TR></TABLE>
Exactly what d said. Was the gsr rebuilt? Not shimming the countershafts, even if you swap cases they need to be reshimmed. I had one break because of that.
Old Feb 10, 2007 | 09:25 AM
smokey2.0's Avatar
Default Re: second counter shaft broke? (ANTILAG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANTILAG &raquo;</TD></TR><TR><TD CLASS="quote">Exactly what d said. Was the gsr rebuilt? Not shimming the countershafts, even if you swap cases they need to be reshimmed. I had one break because of that.</TD></TR></TABLE>use the manual, to get the right specs. check your motor mounts as well, too much engine moveremnt is not good for the transmission as well!
Old Feb 10, 2007 | 10:48 AM
ALL IMPORT's Avatar
Default Re: second counter shaft broke? (smokey2.0)
ive have hasport all the way around & thier arnt any shims on the countershaft never were. i thought they are only on the main shaft.
aslo i broke the lower half of the teeth both times. so shimming it more would raise the shaft up making it worse , no?
Old Feb 10, 2007 | 11:09 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">ive have hasport all the way around & thier arnt any shims on the countershaft never were. i thought they are only on the main shaft.
aslo i broke the lower half of the teeth both times. so shimming it more would raise the shaft up making it worse , no?</TD></TR></TABLE>i should had re-read the post. you need to check your clearances on the mainshaft, and on the differential. those are the two places, where shimming is required!
Old Feb 10, 2007 | 05:06 PM
ALL IMPORT's Avatar
maybe ill go back into the book & see what the deal is. dont see what the mainshaft has 2 do with anything cause thier arnt any gears pressed on & thiers also just a spring washer & washer on the bottom. the problem is with the ring gear & countershaft gear only so far.
aslo if i think abouy it even if i shimmed the counter shaft the snap ring would still put it in the same spot so i would need to shim the diff up a little to center the teeth better.
aslo i notiched the countershaft & mainshft gears the teeth donty line up perfectly thier off by a little is that normal? or do they line up better once u put the case together with the snap ring?
Old Feb 10, 2007 | 05:39 PM
smokey2.0's Avatar
if the mainshaft was shimmed wrong, you would be having issues shifting gears. but it sounds like you need to shim the diff, because if it wobbles inside the case it will self destroy it self. the counter shaft, is pulled up a little(not much), once you close the case.
Old Feb 10, 2007 | 08:38 PM
ALL IMPORT's Avatar
ya i hear what u are saying i have a little backlash noise when i am in gear & off gas so maybe the diff does need some shimming but shouldent i be able to push the diff a little from side 2 side if that were the case? also i got a quaif.
trans is still out cause im waiting for the twin disk so maybe ill mess with it some more.
never tried shimming a diff so we will see. just put new bearings on it a while ago does that mean i need to check shimming again?
Old Feb 10, 2007 | 09:02 PM
smokey2.0's Avatar
check the lash, use the manual. the diff, should have minimal side to side movement. does the transmission make noise, when you get off the gas?
Old Feb 11, 2007 | 05:11 AM
ALL IMPORT's Avatar
ya its got a little noise when your off gas in gear but it perty much goes away once your out of gear ( baybe because of the load factor)
its like a drone sound with a little backlash noise. never had the noise till i broke the pirst countershaft has it ever since
Old Feb 11, 2007 | 10:56 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">ya its got a little noise when your off gas in gear but it perty much goes away once your out of gear ( baybe because of the load factor)
its like a drone sound with a little backlash noise. never had the noise till i broke the pirst countershaft has it ever since</TD></TR></TABLE>well if your hearing that, your mainshaft bearing and maybe your diff bearings might have too much play in them. it might be time, to change a few of those bearings. most of those noises, come from the mainshaft bearing. but if the diff bearings have play in them, it will make it wobble and missaling the ring gear as it touches the countershaft! i hope this makes sense!
Old Feb 11, 2007 | 05:26 PM
ALL IMPORT's Avatar
just putnew diff bearings in so i know those are ok. also i inspected all the other bearings & they seemed to be ok i guess ill pull the trans apart & just check all my clearance again. better to do it now while its still sitting on the bench, rather than breaking something again
Old Feb 11, 2007 | 06:28 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">just putnew diff bearings in so i know those are ok. also i inspected all the other bearings & they seemed to be ok i guess ill pull the trans apart & just check all my clearance again. better to do it now while its still sitting on the bench, rather than breaking something again </TD></TR></TABLE>better be safe, than sorry! good luck with it! maybe once i get my car running again, i might get to see you at moroso!
Old Feb 12, 2007 | 03:08 AM
ALL IMPORT's Avatar
ill be runnig in pinks-all-out this coming weekend, might have a chance of getting at least 1 of the 1000$ spots
Old Feb 12, 2007 | 04:04 AM
smokey2.0's Avatar
good luck man, i'll be in NYC celebrating my son's B-day! have fun
Old Feb 12, 2007 | 02:09 PM
ALL IMPORT's Avatar
have fun.
Old Feb 20, 2007 | 01:56 PM
ALL IMPORT's Avatar
well ran at pinks this weekend went home with a running trans, so cant complain their.
knocked almost a 1sec off the et time. from 11.0 - 10.3. with same power, suprisingly. its amazing what a clutch can do for u
Old Feb 20, 2007 | 05:18 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">well ran at pinks this weekend went home with a running trans, so cant complain their.
knocked almost a 1sec off the et time. from 11.0 - 10.3. with same power, suprisingly. its amazing what a clutch can do for u</TD></TR></TABLE>
Good job man. Your car was MOVING! What was your 60'?
EDIT, saw your other thread, 1.72 very nice.
civgt28
Transmission & Drivetrain
Apr 19, 2011 06:46 PM
JDM-ish
Feb 29, 2008 01:08 AM
91AccordSE
Aug 7, 2004 01:53 PM
