Honda S2000 Honda S2000
f20 valve trane took a dump....Getting a rebuild!!!
Old Feb 9, 2007 | 03:03 PM
pnltnc's Avatar
Default f20 valve trane took a dump....Getting a rebuild!!!
My valve trane's dead, I'm getting all new valves, springs, stage 2 cams...I wanted to know if its a good idea to go with 11 5:1 Je pistons while the motor is apart? What kind of power cans should I expect?
Old Feb 9, 2007 | 03:33 PM
LAS2K's Avatar
Default Re: f20 valve trane took a dump....Getting a rebuild!!! (pnltnc)
if you do, i don't think you expect much power unless you are FI.
Old Feb 9, 2007 | 07:23 PM
Francesco's Avatar
what cams are you getting?
crower makes cams, but i heard they lose power. only other option out there is toda right now.
Old Feb 10, 2007 | 04:33 AM
pnltnc's Avatar
Default Re: f20 valve trane took a dump....Getting a rebuild!!! (Francesco)
skunk 2
Old Feb 10, 2007 | 05:05 AM
Francesco's Avatar
skunk 2's are still pretty new.
how much do they change the curve?
Old Feb 10, 2007 | 01:01 PM
Widebodys2k's Avatar
lol your valve train too, i just went threw a valve dropping out, cause the stem snapped in half, isnt FI fun.
Old Feb 10, 2007 | 03:06 PM
pnltnc's Avatar
Default Re: f20 valve trane took a dump....Getting a rebuild!!! (Widebodys2k)
Yeah I think I'm just going to rebuild the head only. The stock block is already 11.0 compression. Why would I need to go 11.5:1 for?
Old Feb 10, 2007 | 06:05 PM
kane.s2k's Avatar
the skunk2 cams that got tested lost power too and had other issues as well
Old Feb 10, 2007 | 06:07 PM
apSquidFace's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnltnc &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I think I'm just going to rebuild the head only. The stock block is already 11.0 compression. Why would I need to go 11.5:1 for?</TD></TR></TABLE>
i thought you were the one wanting the 11.5 je's? why now are you questioning that? there is no real apparent need or purpose to get higher compression pistons at all to be honest if you are just rebuilding the valvetrain just extra money that you dont need to spend man. put it into a 4.77 final drive
wheelworx
Jan 4, 2006 07:34 AM
delsolb16
14
Nov 9, 2005 04:02 PM
FastGsr95
Aug 24, 2005 04:50 PM
tnsxsear1
Sep 14, 2004 02:23 PM
