Shift Boot Question
Old Feb 9, 2007 | 02:12 PM
RossMathis's Avatar
Default Shift Boot Question
How to do I fix my shift boot?! It no longer sits under the ****, but instead it just sags all the way down to the bottom.
Old Feb 9, 2007 | 02:27 PM
Malakai's Avatar
the plastic ring in the boot is cracked. dont know if this can be purchased seperatly. if not u need a new boot.
Old Feb 9, 2007 | 02:48 PM
BubblegumTate's Avatar
Default Re: (Malakai)
In my CRX, I just wrapped a big rubber band around the shift lever a bunch of times until it was really tight, then stretched the boot over the top of it. Voila, shift boot stays up.
In my VW, I actually used to black zip tie right below the **** to keep that boot up.
Old Feb 9, 2007 | 03:03 PM
MonkeyBoy668's Avatar
Default Re: (BubblegumTate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblegumTate &raquo;</TD></TR><TR><TD CLASS="quote">In my CRX, I just wrapped a big rubber band around the shift lever a bunch of times until it was really tight, then stretched the boot over the top of it. Voila, shift boot stays up.
In my VW, I actually used to black zip tie right below the **** to keep that boot up.</TD></TR></TABLE>
I've done both before, either one will work, at least for a year or two.
Last time it slipped down I junked the OEM boot. Replaced it with an aftermarket boot that screws up against an aftermarket ****. PITA to install & work with (imagine twirling the entire boot around while you're attaching it to the ****), but black leather at least looks nicer than the black vinyl.
b18c inside
Mar 9, 2008 03:53 PM
dawrenn
20
May 19, 2005 05:36 PM
Shinbo
Oct 8, 2004 01:27 PM
pre1udekid
Jul 12, 2004 03:49 PM
