integra cluster conversion on EG help!
so i wired up everything and only my gas and coolent temp doesn't work. I am using a 00-01 integra harness from a type r. it doesnt have a yellow wire to tap into the civic one, so i wired the yellow wire from the civic to a yellow/blue wire on the integra harness. everything works except for the gas and coolent gauge. does a 00-01 integra cluster harness work on a eg? or i have to get the 94+ harness? thanks
btw im using a type r cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2415 »</TD></TR><TR><TD CLASS="quote">yea i used ur diagram, but my integra harness that i have doesnt have a yellow wire</TD></TR></TABLE>
Is there an empty spot where the yellow would be? If there is, use an unused pin and connect the yellow wire of the EG harness to it.
only the blue/white but the fuel and coolent temp wont work, and the other wires that are left is maintenance, low gas light etc. wires that wont work for eg's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2415 »</TD></TR><TR><TD CLASS="quote">only the blue/white but the fuel and coolent temp wont work, and the other wires that are left is maintenance, low gas light etc. wires that wont work for eg's</TD></TR></TABLE>
Connect the yellow EG wire to that blue/white wire.
spl_civic
14
May 5, 2003 12:16 PM
