Is this dp good for 600whp or more?
Old Feb 9, 2007 | 01:18 PM
nitroice40's Avatar
Default Is this dp good for 600whp or more?
This came off my DA and I was going to put it on my DC. I am going to me making in the upwards of 600 to the wheels. Do you think this dp will flow enouf for that hp level. The metal is mild all manderal bent. What about the waste gate dump tube you think thats ok?
thanks
Old Feb 9, 2007 | 02:44 PM
TeamNextGenChris's Avatar
Default Re: Is this dp good for 600whp or more? (nitroice40)
what size is the piping?3" will be fine,4" would be better.
chris
Old Feb 9, 2007 | 02:45 PM
MidwestAutoWorks's Avatar
maybe with open dumptube
Old Feb 9, 2007 | 02:52 PM
Default Re: Is this dp good for 600whp or more? (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">maybe with open dumptube</TD></TR></TABLE>
oh,i didn't even notice that.definitely want to dump the wastgate by itself.
Chris
Old Feb 9, 2007 | 02:57 PM
CRVRX's Avatar
Default Re: Is this dp good for 600whp or more? (TeamNextGenChris)
I have done over 600 with the dump tube running back into the down, I usually run it into the short radius of the bend. You can't hear what's happening when the wasteg gate opens to the air.
Old Feb 9, 2007 | 03:03 PM
Default Re: Is this dp good for 600whp or more? (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">I have done over 600 with the dump tube running back into the down, I usually run it into the short radius of the bend. You can't hear what's happening when the wasteg gate opens to the air.</TD></TR></TABLE>
i'm not saying you can't do it,but it would be more beneficial,esepcially if that downpipe is 2.5".
Chris
Old Feb 9, 2007 | 03:54 PM
Blind-Fashion's Avatar
i'd like to see 600 on 1 tial 38
Old Feb 9, 2007 | 05:52 PM
CRVRX's Avatar
Default Re: (Blind-Fashion)
I don't think a 2.5" down pipe will make 600 either.
What does the size of the wastegate have to do with high HP, It works hard only on low boost.
Old Feb 9, 2007 | 08:49 PM
nitroice40's Avatar
Default Re: (CRVRX)
Its 3", I was thinking that there might be to many bends. There is 4 90s. I cant stand hearing that wg open. If the difference is small its worth it having it quiet. Plus you dont get all the black carbon everywhere.
Old Feb 9, 2007 | 10:12 PM
Default Re: (nitroice40)
Recirc is just fine. but you need a bigger wastegate. or 2 38mm
Old Feb 10, 2007 | 08:06 PM
CRVRX's Avatar
The idea of a wastegate is to keep the boost in check at low boost. At 600 whp the gate is doing very little as it isn't bleeding off much pressure .
My single 38m Tail gate holds boost from 11 psi all the way to 34psi.
Old Feb 11, 2007 | 11:15 AM
nitroice40's Avatar
Default Re: (CRVRX)
I was thinking the same thing, I am going to be running max boost out of my T4 62-1 untill I get a bigger turbo. Then I was thinking about adding another 38. But is that going to be too much?
Old Feb 11, 2007 | 03:35 PM
maxspeedhonda's Avatar
Default Re: (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">The idea of a wastegate is to keep the boost in check at low boost. At 600 whp the gate is doing very little as it isn't bleeding off much pressure .
My single 38m Tail gate holds boost from 11 psi all the way to 34psi.</TD></TR></TABLE>
Exactley, I've made just under 600 whp with a single 38mm with a 1 bar spring, held 28psi rock hard.
Old Feb 11, 2007 | 06:52 PM
CRVRX's Avatar
Default Re: (maxspeedhonda)
It seems alot of people don't really know what the wastegates job is .
Old Feb 11, 2007 | 06:57 PM
Quickgti1.8t's Avatar
Default Re: (CRVRX)
lot of people do dual wastegates cause they want to run 7psi on a GT40 for some reason... I had a 38mm and ran 25psi on a 35r with no problem, never boost creep or anything.
Cory Matthews
Mar 21, 2007 10:11 PM
nitroice40
Feb 9, 2007 11:57 PM
TegoDC5
Feb 23, 2006 08:48 PM
DC5_R
Aug 8, 2005 11:09 PM
EGlovr
Jun 8, 2004 02:31 PM
