P30 Pistons into my ls vtec...few other question too...help ASAP..!!!
Old Feb 9, 2007 | 10:10 AM
Lscivic1999's Avatar
Default P30 Pistons into my ls vtec...few other question too...help ASAP..!!!
i have a complete b16 swap in my 99 civic, i just got a cheap 94 b18b block for a 100$ .so im finally doing my ls vtec soon if i use my p30 piston what compression should i expect.?.What else may i need to do the whole swap?
.any comments or recomendation will be nice
on the way are's
golden eagle oil line kit
also have blox stage 2 cams will valvetrain and retainers
AEM cam gears plus I/H/E
what should i expect from this set up thought from the top of your head just want to know?
Old Feb 9, 2007 | 10:11 AM
akandok's Avatar
Default Re: P30 Pistons into my ls vtec...few other question too...help ASAP..!!! (Lscivic1999)
cp ratio should same as the si.. the gsr head adds .2 cp ratio.
Old Feb 9, 2007 | 10:54 AM
Default Re: P30 Pistons into my ls vtec...few other question too...help ASAP..!!! (akandok)
even with the LS Block ?
Old Feb 9, 2007 | 11:11 AM
akandok's Avatar
actually if you use the p30 pistons youre gonna be at about 12.2:1
here is a nice tool http://www.zealautowerks.com/
Old Feb 9, 2007 | 11:22 AM
Alright that should be enough then with stage 2 cams ,valve train, adjustable cam gears I/H/E stage 1 exedy clutch with a 10lbs flywheel or maybe upgrading that later on i just wanna get pass 200whp all motor on my set up...and im also using a GSR tranny will that make a lot of diference than the b16?
thanx man that link is useable..
but whats this ....Enter total amount head has been milled and block decked.??
Modified by Lscivic1999 at 12:36 PM 2/9/2007
Old Feb 9, 2007 | 11:18 PM
akandok's Avatar
yes, the b16 has shorter gears then the gsr. faster accelaration but lower top end. also really high rpms on highway.. about 4500rpms at 75
block decking = http://www.hanzenginehouse.com....html
milled head =
so long story short either of these would raise your compression depending on how much the block is decked or your head milled..
feel free to correct me if im wrong
Old Feb 10, 2007 | 03:39 PM
am using a gsr tranny thought ..is that a bad idea i think myself that gsr tranny have a great 3rd
Old Feb 12, 2007 | 12:44 PM
akandok's Avatar
i like the gsr tranny. if you are making decent power then that makes up for the shorter gears of the b16
Old Feb 12, 2007 | 03:39 PM
alright i just gonna leave like that then
low13da9
Apr 26, 2010 06:53 PM
dustin_crxsi
Oct 10, 2007 01:41 PM
ls_bitik
May 27, 2007 11:56 AM
LSVTEC426
11
Apr 12, 2007 06:49 AM
blwn95civic
Oct 12, 2006 01:39 AM
