Making a auto into a manual 97-01
Old Feb 9, 2007 | 09:58 AM
mafia's Avatar
Default Making a auto into a manual 97-01
Well Im making my 00 lude into 5 speed and SH, and how do I know EXACTLY were to drill out the clutch cylender and for the pedal? (I allreaddy drilled it out, but the pedal looks like its to high and too to the left.) so im thinking the pedal is bent or i drilled wroung? any one with any idea?
Old Feb 9, 2007 | 10:04 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: Making a auto into a manual 97-01 (mafia)
why do you want to make it an SH? its just more trouble
besides i think the sh engine bays are different to fit the ATTS unit
Old Feb 9, 2007 | 11:00 AM
Chuckles99SH's Avatar
Default Re: Making a auto into a manual 97-01 (raylude)
Nope engine bays are the same, the suspension is a little different in the front but not much. Dont bother with a ATTS swap into your car, it will be a huge pita. It would probably require you take a front clip and swap the suspension, motor, tranny, ecu, atts ecu and i think that there are some sensors in the steering column that feeds info to the atts ecu about steering position. If i were you I would get a Type-S SiR swap and do that for the LSD and 11.1 compression you would be plenty happy with that.
Old Feb 9, 2007 | 09:07 PM
raylude's Avatar
Default Re: Making a auto into a manual 97-01 (Chuckles99SH)
thanks for correcting me and i think your talking about the SIR S spec not the type S that came with ATTS witch would still be like putting a Sh swap in his lude
if you dont want to spend the extra money on getting a better motor and trany like the SIR S spec you can just leave your motor alone and swap that crappy auto trany for a base 5 speed trany and put a quaife LSD in it
Old Feb 9, 2007 | 09:56 PM
mafia's Avatar
Sorry for poor info... I bought a half stripped 00 lude that had auto motor before. It had no seats and no motor. Then i bought a lude that is a 99 and it is a SH (hit in front). So i allready swaped the wiring from the back bumper to the front bumper. and the SH motor is allreaddy in. Im just having truble setting up the stupid clutch pedal
Old Feb 10, 2007 | 06:49 AM
raylude's Avatar
oh ok then i hope the ATTS doesnt give you too much trouble
and as far as putting the pedal in, i would ask my mechanic who did it to my car when i had it swaped to a 5 speed but hes on vacation right now
Old Feb 11, 2007 | 07:57 PM
mafia's Avatar
k, if u can find out that would be super
Old Feb 11, 2007 | 09:04 PM
Max Kling's Avatar
I might be able to help you out tomorrow, Im doing a Euro R swap in a auto base. Project is ending up to be a total pain in the ***.
Tomorrow we are mounting up the pedals.
Old Feb 13, 2007 | 10:36 AM
mafia's Avatar
Default Re: (Max Kling)
take good pic, thanx! :D
Old Feb 13, 2007 | 09:54 PM
Max Kling's Avatar
Getting hung up on some other things, like switching out oil pumps and what not so its getting delayed.
Ill take pics.
Old Feb 21, 2007 | 03:42 PM
mafia's Avatar
bump, for the pic's
Old Feb 21, 2007 | 05:27 PM
gaborn73's Avatar
yo can anyone recommend a tech
to do a auto/5spd swap in Northern VA?
5th gen
Old Feb 22, 2007 | 07:14 PM
mafia's Avatar
Default Re: (gaborn73)
none that i knoe of, I would help u if you were from ID.
Old Feb 22, 2007 | 07:45 PM
95f22a1's Avatar
Default Re: (mafia)
it would be so much easier to buy a lude that's already a 5-speed
Old Feb 22, 2007 | 08:52 PM
RedDC5's Avatar
Default Re: (95f22a1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95f22a1 &raquo;</TD></TR><TR><TD CLASS="quote">it would be so much easier to buy a lude that's already a 5-speed</TD></TR></TABLE>
Precisely the reason why Im just waiting to buy a new car instead of doing the swap...such a pain...
Old Feb 22, 2007 | 09:41 PM
roller3804's Avatar
Default Re: (FerioEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioEG &raquo;</TD></TR><TR><TD CLASS="quote">
Precisely the reason why Im just waiting to buy a new car instead of doing the swap...such a pain...</TD></TR></TABLE>
It's not a pain if your a DIY kind of person. Plus who wants to swap out all of the parts you spend time and money on from your old car to your new car. Keep your car man. 5speed swap is easy as long as u have all the parts you need.
Old Feb 22, 2007 | 09:42 PM
roller3804's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafia &raquo;</TD></TR><TR><TD CLASS="quote">Well Im making my 00 lude into 5 speed and SH, and how do I know EXACTLY were to drill out the clutch cylender and for the pedal? (I allreaddy drilled it out, but the pedal looks like its to high and too to the left.) so im thinking the pedal is bent or i drilled wroung? any one with any idea? </TD></TR></TABLE>
Was there not a cover over where the clutch cylinder should have been?
Old Feb 23, 2007 | 03:54 AM
tacticalcustoms's Avatar
Default Re: Making a auto into a manual 97-01 (roller3804)
ya there should have been a cover held there with 2 bolts that you remove to get your hole.
Old Feb 27, 2007 | 05:28 PM
mafia's Avatar
Default Re: Making a auto into a manual 97-01 (tacticalcustoms)
I wish there was, but no... mabe cuz its a 2000? Well i dono, but i Almost have every thing done. I just need to put the upper brkt for the peddal.
Old Feb 27, 2007 | 07:11 PM
Max Kling's Avatar
There is a cut out on the material that covers the firewall in the shape of the MC, you take the gasket from the MC and put it in the cut out and trace with the marker. Then cut them out and make sure to get the spacers or shims, because your going to have to do it. Also if you cant figure out how to get the car to turn over PM me and I can help you out because they left out how to wire the safety switch for the starter.
ferio-ichi3
27
Apr 16, 2013 12:48 PM
Bright13
Dec 14, 2009 09:00 PM
Max Kling
Jan 22, 2007 08:03 AM
5lugSlug
Jul 6, 2005 08:11 PM
lunarcry
Mar 31, 2004 12:03 PM
