mustang throttle body on b series???
any body have any luck using a 86-93 5.0 mustang throttle body on their b-series. im going to be using the jg victor x manifold and dont feel like shelling out $300 for a throttle body specifically for a honda/acura when the mustang one is usually at least a hundred cheaper if not more! appreciate any info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conquer11s »</TD></TR><TR><TD CLASS="quote">any body have any luck using a 86-93 5.0 mustang throttle body on their b-series. im going to be using the jg victor x manifold and dont feel like shelling out $300 for a throttle body specifically for a honda/acura when the mustang one is usually at least a hundred cheaper if not more! appreciate any info.</TD></TR></TABLE>
yes, Edelbrock sells an adapter to bolt a 70mm or 75mm mustang throttle body onto a honda/acura intake manifold
they are like $25 - pm me if you need one
Also you are going to have to change your TPS voltage range in your ECU and your going to have to either hard wire the TPS sensor in to your harness or put some sort of connector on your engine harness and the new TPS.
