question regarding to crower stage2 63402A-2 cams
Old Feb 9, 2007 | 04:27 AM
integraboy22's Avatar
Default question regarding to crower stage2 63402A-2 cams
hey guys :
Just a quick question, i got offered a really good deal for a crower stage2 63402a-2 stage 2 cams , just wondering if it is too big for my set up, i'm running a stock JDM type r engine with basic I/H/E , and the cams come with new VS+retainer, i will use hondata to tune it , and also getting a 255 fuel pump, got FPR +spoon cam gears already, need your opinion please
Old Feb 9, 2007 | 09:02 AM
GetawayInMoscow's Avatar
Default Re: question regarding to crower stage2 63402A-2 cams (integraboy22)
they will be great...you will like them a lot
Old Feb 9, 2007 | 04:57 PM
NAlover's Avatar
Default Re: question regarding to crower stage2 63402A-2 cams (GetawayInMoscow)
I think you will like them..
I got the stage 3 LS/V 11.7CR street-tunned and they are pretty good..
Old Feb 9, 2007 | 10:04 PM
thanks man, just two questions now, (1) will i overcamed (2) i heard some brakeage cases for the old crower stage2 , and was told the newer version one was better, so my question how can i tell the one i'm getting is newer version or old one, cheers
Old Feb 10, 2007 | 11:12 AM
Default Re: (integraboy22)
1) def wont be over cammed
2) the chance of breaking them are so small, those were only a small batch
Old Feb 10, 2007 | 12:01 PM
thanks man, will look into it , knowing my luck i will get one of the small batch, cos bad thing happend to me before, can you believe brand new oem honda water pump broke on me, nearly killed my engine, what happened was the pulley came out of the shaft and half way went through the lower timing belt cover, hehe, that is like one of million man
Old Feb 10, 2007 | 01:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboy22 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, will look into it , knowing my luck i will get one of the small batch, cos bad thing happend to me before, can you believe brand new oem honda water pump broke on me, nearly killed my engine, what happened was the pulley came out of the shaft and half way went through the lower timing belt cover, hehe, that is like one of million man</TD></TR></TABLE>
**** it might be even smaller of a chance than one in a million. damn
well good luck with the cams, you will like them, i just sold mine to someone on ebay
b16bri
Oct 15, 2010 05:51 PM
MichaelPal
Feb 11, 2006 10:52 AM
TURBODC4TEG
Feb 4, 2006 01:22 PM
b16vtecsol
16
Feb 27, 2004 10:38 PM
xJ.SLOTHx
Jan 24, 2003 05:49 AM
