Car heater not getting hot, help//
Old Feb 8, 2007 | 05:56 PM
GREENMOB$TER's Avatar
Default Car heater not getting hot, help//
I turn my heat on my car the whole way, and it only gets warm, not even enough to heat the car. help someone? Do you think it could be a bad thermostat??
Old Feb 8, 2007 | 06:06 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Car heater not getting hot, help// (GREENMOB$TER)
check if the motor is working
Old Feb 8, 2007 | 09:02 PM
b18bme's Avatar
Default Re: Car heater not getting hot, help// (It's*BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">check if the motor is working</TD></TR></TABLE>
Honestly what kind of answer is that???
Anyways does your temp guage show your car is warming up??? Usually if the thermostat is bad your car wont warm up. Or like when mine was bad it would warm up when at a stop, but when i started driving my guage would drop all the way to cold.
Old Feb 8, 2007 | 09:15 PM
suzawa94's Avatar
Default Re: Car heater not getting hot, help// (b18bme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bme &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways does your temp guage show your car is warming up??? Usually if the thermostat is bad your car wont warm up. Or like when mine was bad it would warm up when at a stop, but when i started driving my guage would drop all the way to cold. </TD></TR></TABLE>
x2. if your heater is not working could it could be two things. your thermostat could be bad (stuck open) and not warming up the car properly.
another thing is your mode door which switches from hot to cold. what is does basically is open a door which allows the hot coolant to warm the air. if you can hear the mode door open/close (operation should be smooth with some resistance) then you have a faulty heater core.
cslegacy
Feb 14, 2008 12:20 AM
gsrbeast
Apr 7, 2007 12:29 PM
5g
Sep 3, 2006 09:26 AM
maxboost_50psi
Jul 7, 2005 07:11 PM
pr8elu8desi
Jun 21, 2004 06:18 PM
