where is the ecu located in a 95 vtec prelude?
Old Feb 8, 2007 | 05:29 PM
accord03coupe's Avatar
Default where is the ecu located in a 95 vtec prelude?
where can you guys get a stock ecu 95 vtec prelude, and how much its would cost?
thank!
Modified by accord03coupe at 3:41 AM 2/9/2007
Old Feb 8, 2007 | 05:31 PM
SteveoBA8's Avatar
Default Re: where is the ecu located in a 95 vtec prelude? (accord03coupe)
Where the front passenger's feet are. Pull the carpet back, say hello to the monster that is the ecu shield.
Old Feb 8, 2007 | 07:09 PM
M2B4's Avatar
Default Re: where is the ecu located in a 95 vtec prelude? (SteveoBA8)
check ebay for a replacement
Old Feb 8, 2007 | 09:03 PM
Default Re: where is the ecu located in a 95 vtec prelude? (M2B4)
are those si and vtec prelude 92-95 ecu have same harness plug in?
thank!
Old Feb 8, 2007 | 09:26 PM
MLBZ521's Avatar
The Si & VTEC ECU's are different. But a OBD1 Si ECU and a OBD1 VTEC ECU has the same plugs. However a OBD1 VTEC ECU has different plugs than a OBD2 VTEC ECU.
I'm not sure exacting what you mean.. But that should cover it...??
[Edit: Although the Si Harness doesn't have a few wires that the VTEC Harness does.. Two I believe it is...]
Old Feb 9, 2007 | 08:16 AM
Preludepradit's Avatar
Yeah those shields for the ECU are a pain in the BUt* When I swapped my ecu, I didnt even put it back in because I couldnt get the bolts to thread because I didnt have any magnetic tipped sockets.
Old Feb 9, 2007 | 10:38 AM
SteveoBA8's Avatar
Default Re: (Preludepradit)
It's not that hard to get the shield on and off, i use a small telescopic magnet to get the nuts started.
Old Feb 9, 2007 | 11:41 AM
Default Re: (SteveoBA8)
what happen if you put a odb1 si ecu in a 95 vtec prelude?
Old Feb 9, 2007 | 11:43 AM
rawNArsxS's Avatar
Default Re: (accord03coupe)
no vtec
Old Feb 9, 2007 | 11:45 AM
fastlude69's Avatar
Default Re: (rawNAprelude)
get a gsr ecu and chip it to run it or another compatible ecu
Old Feb 9, 2007 | 08:56 PM
Default Re: (fastlude69)
what is the redline of the si odb1?
thank, i think a got a si odb1 in my 95 vtec prelude, i didn't feel any pover when go over 5500 rpm
Old Feb 9, 2007 | 08:59 PM
M2B4's Avatar
6400
Old Feb 9, 2007 | 10:35 PM
VtecPrelude95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord03coupe &raquo;</TD></TR><TR><TD CLASS="quote">what happen if you put a odb1 si ecu in a 95 vtec prelude? </TD></TR></TABLE>
after i got into my car accident, before the insurance took the totalled car, i swapped the interior and took out the p13 VTEC ecu and put the si ecu in there. car starts up, but ill feel sorry for whoever buys it and fix it and then drive it and realizes...whoa! no VTEc....pu' ahahaha...( also took out the abs cpu)
Old Feb 10, 2007 | 12:48 AM
russlan44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Where the front passenger's feet are. Pull the carpet back, say hello to the monster that is the ecu shield.</TD></TR></TABLE>
thats for sure like 6 bolts if not more the 5 gen preludes have only 4 and the ecu comes out with the shield
Dave Brabant
Jun 28, 2018 01:17 PM
rmiller
Feb 1, 2008 10:10 PM
accord03coupe
Nov 30, 2006 07:23 AM
