b18c1 h beam eagle rods in lsvtec?
so i found a good deal on rods and pistons but not sure if it will work on my setup. im using a stock ls crank and a b18a1 block. i am goin building my motor for boost, and the pistons r standard 81mm which is the same as my block so i know those will fit. i was just wondering if the b18c1 h beam eagle rods will, im using a b16a2 head if that helps.
slammedcoupe
Jul 18, 2004 06:53 PM
GSRacer
Jan 25, 2002 02:09 PM
