99-00 power window ect conversion Without floor harness..
Old Feb 8, 2007 | 03:02 PM
ant$missShift's Avatar
Default 99-00 power window ect conversion Without floor harness..
hey guys. i bought a 99 hatch shell that had all the SI/Ex conversion doors with mirrors windows and locks.. well i got the car all together and put a battery in and the power options didn't work.. so i started going through it and the guy i got the car from never finish the conversion. he just had it sitting in there with wires spliced and going into the cabin but nothing hooked up. the thing is thats its going to be my daily driver and im going to have it painted next week and i don't wont to have to take the fenders back off after paint so im trying to get this done now and i cant find a 99-00 ex floor harness anywhere locally..
So im trying to find out how to do it without the harness.. I found jackmoves Diagram on here buts it for a 96-98 and not all the colors match the 99.. just wonder if anyone could help me out.. thanks alot.
Old Feb 8, 2007 | 04:14 PM
Default Re: 99-00 power window ect conversion Without floor harness.. (sxeonerX)
TTT
Old Feb 8, 2007 | 04:17 PM
B16B_coupe's Avatar
HRD PKR
so what u want is the 99-00 wiring diagram for the floor? if so aim me. florencekevin is my name and ill get u the info
Old Feb 8, 2007 | 04:44 PM
Default Re: 99-00 power window ect conversion Without floor harness.. (B16B_coupe)
it may help me out... ill pm you. BUmp
Old Feb 8, 2007 | 05:13 PM
BUmpo
Old Feb 8, 2007 | 08:13 PM
TTTT
Old Feb 9, 2007 | 01:02 PM
Old Feb 9, 2007 | 05:32 PM
TTT
Old Feb 10, 2007 | 04:34 AM
no one
Old Feb 10, 2007 | 05:33 AM
i have to finish this weekend . someone help me out.lol. i can only find a 4 door harness can i make that work??
Old Feb 10, 2007 | 06:37 PM
TTT
Old Feb 10, 2007 | 06:57 PM
TTTT
Old Feb 10, 2007 | 07:38 PM
vtec4lyfe's Avatar
well when i did mine the harnesses ******* clicked right in and they work after i put fuses in, too bad that idiot fucked up and chopped the wires.
Old Feb 11, 2007 | 06:13 AM
Default Re: (vtec4lyfe)
yea.. ........................ BUmp
Old Feb 11, 2007 | 11:00 AM
JSPECSIR's Avatar
Default Re: (sxeonerX)
i put in oem locks, windows, and switches. i didnt use any oem harnesses or wiring. you can do it.
Old Feb 11, 2007 | 03:59 PM
Default Re: (JSPECSIR)
well help me out. lol
Old Feb 11, 2007 | 04:02 PM
EK FLY's Avatar
<FONT SIZE="17">BUMP</FONT>BC i BOUGHT A 99 EK SHELL TOO AND THE WIRES WERE CUT TOO WEE NEED INFO
Old Feb 12, 2007 | 03:17 AM
Default Re: (super-hatch)
TTTTT
Old Feb 12, 2007 | 03:54 AM
JSPECSIR's Avatar
ok first the door locks only need 2 relays to work, or a dei 451m door lock module. you feed your lock switch's input 12v or ground whichever you prefer. then you take its outputs and trigger the relays or the 451m. i use neg, then feed my alarms neg inputs into the relays as well. then take the outputs and go to the lock motors, done. if your not used to wiring up relays, get a 451m. go to best buy install bay, they will prolly give you one as they will have hudreds of them thrown below the counters. and these come with instructions so you know where the hot and ground goes. now the windows. you need a dei 530t window automation module.(check ebay 1st.) you will do the same with the window switches. feed the switch 12v or ground on its input, connect the out to the in on the 530t, and the out from the 530t to the window motors. this module will also give you one touch up/down of both windows. this is what i did, ant it all works perfect. i dont even have the plugs for the switches. i had to trim the plastic off the pins where the plugs go and solder wires on to go out to my 451m and my 530t.
Old Feb 12, 2007 | 04:18 AM
Slothy's Avatar
When I put them in my 99 hatch, I came across this on H-T, not sure who made it, but it helped me a lot.
Old Feb 12, 2007 | 12:52 PM
Default Re: (Slothy)
thats the diagram i found.. ^ but not all the colors match.. theres like 5 colors or so that dont match.... .
JSPECSIR.. im so lost on what u said.lol.
Old Feb 12, 2007 | 03:23 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxeonerX &raquo;</TD></TR><TR><TD CLASS="quote"> JSPECSIR.. im so lost on what u said.lol.</TD></TR></TABLE>
sorry man thats the best i can do for you. if i had more days off id tell you to come to raleigh with a couple cases of beer and we'd get it all working.
Old Feb 12, 2007 | 03:37 PM
JSPECSIR's Avatar
maybe this helps.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Accessory
[PRINT THIS PAGE]
12volts white + ignition harness
Ignition black/yellow + ignition harness
Parking Lights+ red/black keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Parking Lights-
Headlight
Trunk/Hatch Release
Power Sliding Door
Speed Sense
Wipers
LF Window up/dn red/yel - red/blu A drivers door switch
RF Window up/dn blu/yel - blu/org A drivers kick panel
LR Window up/dn grn/yel - green A drivers kick panel
RR Window up/dn yellow - yel/grn A drivers kick panel
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Remote Start
[PRINT THIS PAGE]
Starter black/white + ignition harness or
Notes: In 6 pin white plug behind fuse box
Second Starter
Second Ignition yellow + ignition harness
Third Ignition
Accessory white/black + ignition harness
Second Accessory
Keysense
Power Lock green/white - keyless entry module
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Unlock Motor blue/red drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray - OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
No Type:
N/A
Part #: N/A
Notes:
Old Feb 12, 2007 | 04:22 PM
thanks man. thats helps a lil more.. ill try to figure it out hte best i can.. and if it works out ill do a lil write up.. thanks tho.
Marvin1985
Oct 28, 2013 07:06 PM
LoneAutosport
Jun 24, 2009 06:49 PM
kasso
Nov 30, 2006 08:49 PM
