gas mileage???
i have a 89 hatch... it has a d15 with a d16a6 head w/ si tranny. Still running dpfi... But i am guessing the tank is around 10 gal or so but i am lucky if i am getting 230 miles out of the tank... tell me whats wrong. cant drive in fifth much cause it will bog if i am not over 80. it will do 88 in second though ha ha!!
Don't do 88 in second
. Could be a number of things: are you still running the DPFI ECU? Bad O2 sensor, fuel injectors, filter, pump, spark plugs, air filter. You should be getting at least 30mpg if you don't drive like an idiot.
88 in secnd isnt even in the redline but thats very rarely..... but anyways... plugs are good but a while back i ahd a bad vacuum leak to the map sensor but thats fixed now.... salted the motor... new plugs runs great but real sluggish on hot days to about 3500 rpm... who ever owned it before me had an safc on it. and yes it is running a pm5 ecu...
efjones9
29
Sep 2, 2009 02:30 PM
SalmanzCivic
26
Jan 7, 2005 01:02 PM
