Seat belt problem
I bought a set of seat belts from someone online. When they showed up, I discovered that both belts are retracted into their mechanisms, and they won't pull back out.
I've heard of 2 other people that this has happened to.
I looked around on the units, and I can't seem to find a button/lever that will release the belts.
Has anyone ever heard of this? Does anyone know how to release the belts??
Thanks!
Modified by nihkon at 4:05 PM 2/8/2007
Thanks!
just bolt them on, after you do that they will work. i had this same problem with some seatbelts i put in my sedan. i thought they were busted, but when i installed them, they worked fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihkon »</TD></TR><TR><TD CLASS="quote">Anyone else have info on this?</TD></TR></TABLE>What the other dude told you is right. I wok for a parts department and carmax ordered a new seat belt from us and tried to return it because of the same thing you described. We tried to explain it t them but the dumb bastards wouldn't listen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihkon »</TD></TR><TR><TD CLASS="quote">lol. Cool. cool. So what is it that makes it work once the unit is bolted into the car? I'm not questioning it. . .just curious how it works.</TD></TR></TABLE>I have no idea
it is probably some weird gravity latch. the same mechanism that locks the belts when your in a crash is the mechanism that is causing them to not move currently.
silverEH2
13
Mar 26, 2003 08:27 AM
