Honda S2000 Honda S2000
J's Front Fender. Im confused as hell. How wide 20mm? 40mm?
Old Feb 8, 2007 | 09:29 AM
- BSeRiouS -'s Avatar
Default J's Front Fender. Im confused as hell. How wide 20mm? 40mm?
Wassup guys. I am setting up my buddy for some new wheels for his s2k, but I am having a hard time figuring out if the j's front fender is 20mm each side or 40 mm each side. I'm getting a differnt variety of answers and its confusing me. I don't want to mess up his front set up by either being to "sunk in" or to "stuck out".
J.E.T/Santos you guys are or was running this set up correct? Any input is perfect. Thanks
Modified by OBSeRiouSo at 10:54 AM 2/8/2007
Old Feb 8, 2007 | 09:31 AM
noturtypicalone's Avatar
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (OBSeRiouSo)
40mm wider per side. i've seen 17x9+20something on them which confirmes the 40mm.
one of the members on s2ki also got 17x9+22 for his j fenders.
Old Feb 8, 2007 | 09:39 AM
Mr. Projekt's Avatar
* B A N N E D *
J's widen 20mm per side, 40mm in total. JET and I are running the Varis set up with the same width increase.
The front Blister Fender kit replaces the OEM fenders and are not "over-fenders", the rears are.
Old Feb 8, 2007 | 09:45 AM
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (Mr. Projekt)
aj racing says you can go as low as 17x9+28 with a 255.
a 20mm fender will not let that clear.
they're 40mm per side.
also tp-ap1 runs 17x9+44 all around on varis fenders (15mm) and he had to shave the fenders some and add some camber to clear.
Old Feb 8, 2007 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">J's widen 20mm per side, 40mm in total. JET and I are running the Varis set up with the same width increase.
The front Blister Fender kit replaces the OEM fenders and are not "over-fenders", the rears are.</TD></TR></TABLE>
Okay. So the J's Fender is 20mm per side, 40mm total correct?
then...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noturtypicalone &raquo;</TD></TR><TR><TD CLASS="quote">40mm wider per side. i've seen 17x9+20something on them which confirmes the 40mm.
one of the members on s2ki also got 17x9+22 for his j fenders. </TD></TR></TABLE>
and this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noturtypicalone &raquo;</TD></TR><TR><TD CLASS="quote">aj racing says you can go as low as 17x9+28 with a 255.
So its 40mm each side/ 80mm total?
Old Feb 8, 2007 | 09:54 AM
* B A N N E D *
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (noturtypicalone)
They're +20mm, more like 25mm when I measured them out. I can fit OEM rear 17s on there with a 5mm spacer and 255 tires.
Old Feb 8, 2007 | 09:57 AM
My head hurts
so there 20mm ("25mm") each/ 40mm both. Not 40 each side.
First i thought it was 40 each, now 20 each, then i jumped back to 40 each, now im jumping back to 20 each., then back to 40 each.
But like what they said. I am seeing someone run a CE 17x9+22 with J's fenders, so it has to be a 40 each then correct. Blah.
Old Feb 8, 2007 | 10:00 AM
that can't be. they wouldn't clear a 17x9+28 with a 255 if that were the case.
hunterez has asm fenders (25mm) and 17x9+45. and it clears, but you can tell there's not much more space.. .not enough to clear a +28 on a 255
and i'm almost positive i can fit an oem rear with a 5mm spacer and 255 on oem fender.
the wheel+spacer would put the wheel 14mm past the oem 17. that's hardly agressive enough to cause a problem. if it does rub slightly, it wouldn't without the spacer.
OBSeRiouSo, i see where the confusion is coming in :lol:
here's a qoute from Aj Pwr on s2ki.
"Wheels to work with the J's fender setup , you can run up to 17x9 +28 offset with 255 tires but I will suggest 17x9 +35 to give it a bit more clearance."
you're talking about wheels that push out 45 and 52mm further out than oem 17's.
Modified by noturtypicalone at 2:15 PM 2/8/2007
Old Feb 8, 2007 | 10:05 AM
* B A N N E D *
17x8 +38 with a 235/40 tire fits. I don't know about putting a +28 up front though... I'd need something aggressive in the back to match, which means more parts, more work, more headaches...
Old Feb 8, 2007 | 10:06 AM
lol so is it 40mm each? or 20mm each? Can you guys see why Im confused lol
Old Feb 8, 2007 | 10:07 AM
edited my post ^ with more info
Old Feb 8, 2007 | 10:11 AM
papa5murf's Avatar
40mm per side.... total 80mm
Old Feb 8, 2007 | 10:12 AM
So its 40mm each then!
right?!? hahaha. Its going to be a confusing set up because my buddy is gonna run these fenders with a BBK so I want to make Sure i get the most out of this set up. 40mm it is. Final answer....lol
Old Feb 8, 2007 | 10:13 AM
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (papa5murf)
Papa seems confident
Old Feb 8, 2007 | 10:19 AM
papa5murf's Avatar
ROFL, why not just call up AJ racing? Don't they have these fenders on their car?
Old Feb 8, 2007 | 10:22 AM
Jet.'s Avatar
It's 40mm each side and 80mm total. A friend of mine had the J's fenders and it's wide as hell. I hope this clears it up for you.
He was running these wheels:
Work S1 3pc
Front are 18x7.5 +37 offset with 225/40/18 tires
Here's how they looked with the J's fenders with a lot of clearance:
I win! So where's my cookie?
Old Feb 8, 2007 | 10:27 AM
papa5murf's Avatar
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (J.E.T.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.E.T. &raquo;</TD></TR><TR><TD CLASS="quote">
I even got you milk..
Old Feb 8, 2007 | 10:28 AM
seee i tolddd you
Old Feb 8, 2007 | 10:29 AM
Jet.'s Avatar
LOL! Thanks!
Old Feb 8, 2007 | 10:31 AM
AJ said 40mm. Bulletproof said 20mm. People Said 40mm. Others said 20mm lol
Done. Thanks foolios
Jet.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">17x8 +38 with a 235/40 tire fits. I don't know about putting a +28 up front though... I'd need something aggressive in the back to match, which means more parts, more work, more headaches... </TD></TR></TABLE>
That's one reason I ended up getting the fenders. The J's fenders are too wide for my taste.
Old Feb 8, 2007 | 10:50 AM
It looks like he has about another 2 inches of play under there. Hmmmmm...
9.5 +37 should be perfect under with a nice stretch. hmmmm...
Old Feb 8, 2007 | 11:09 AM
* B A N N E D *
Damn Don that's nice~!
Old Feb 8, 2007 | 12:51 PM
Azcheron's Avatar
do the j's fender work with the OEM front bumper?
Old Feb 8, 2007 | 06:35 PM
Francesco's Avatar
Default Re: J's Front Fender. Im confused as hell. How wide 20mm? 40mm? (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">do the j's fender work with the OEM front bumper?
yes
