Side Marker Blinking fix?
Old Feb 8, 2007 | 07:24 AM
GQej1's Avatar
Default Side Marker Blinking fix?
I don't know where this topic should be posted so I will post it here because it's an appearance thing.
My sidemarkers on my EJ1 light up when I turn the turn signals on but I want them on when the running lights are on. Where do I need to change the wiring.
Also I searched "side marker" and found no information on this.
Old Feb 8, 2007 | 07:25 AM
FhCRubarb's Avatar
Default Re: Side Marker Blinking fix? (GQej1)
Subscribed
Old Feb 8, 2007 | 07:27 AM
Baggy Spandex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know where this topic should be posted so I will post it here because it's an appearance thing.
Also I searched "side marker" and found no information on this.</TD></TR></TABLE>
Get a probe and test the power in each corner light plug. Place it on each 'pin' in the socket, and when you find which wire has power going to it with the running lights on, wire the sidemarkers into that wire.
Old Feb 8, 2007 | 07:30 AM
GQej1's Avatar
Default Re: Side Marker Blinking fix? (NAisBEST)
Awesome. Thank you.
Old Feb 8, 2007 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GQej1 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome. Thank you.</TD></TR></TABLE>
Old Feb 8, 2007 | 07:56 AM
Markland Photo's Avatar
whatever wire its running to on the headlight harness then switch it to the other one and try it then. but i hope you know that its SUPPOSED to be on for your blinker not pking lights, but its your car
Old Feb 8, 2007 | 07:59 AM
94WhYt_EG1's Avatar
Default Re: (bulletspastsunset)
here ya go...u spelt sidemarkers wrong...lol
https://honda-tech.com/zerothread?id=1868891
Old Feb 8, 2007 | 08:05 AM
GQej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94WhYt_EG1 &raquo;</TD></TR><TR><TD CLASS="quote">you have them cross wired! i have mine set up where the positive of the side marker is spliced into the negative of the corner and the negative of the sidemarker to the positive the turn signal. this way the sides are on along with the day lights and alternate when the blinker is on.</TD></TR></TABLE>
There we go. That's what I want. Thanks guys.
Old Feb 8, 2007 | 08:11 AM
GQej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulletspastsunset &raquo;</TD></TR><TR><TD CLASS="quote">whatever wire its running to on the headlight harness then switch it to the other one and try it then. but i hope you know that its SUPPOSED to be on for your blinker not pking lights, but its your car</TD></TR></TABLE>
I know. Thanks. I like the way it looks better when they are on at night.
Old Feb 8, 2007 | 10:00 AM
2coupes's Avatar
splice the power wire from the sidemarker into the red/black wire in the corner light instead of the green/black wire it's spliced to now
Old Feb 8, 2007 | 10:13 AM
GQej1's Avatar
Default Re: (2coupes)
Will do. Thanks
Old Feb 9, 2007 | 04:33 PM
GQej1's Avatar
That **** worked like a charm. Thanks guys.
Old Feb 9, 2007 | 05:01 PM
Capt. Jimbo McSubipants's Avatar
are they gonna blink still tho?
Old Feb 9, 2007 | 05:16 PM
GQej1's Avatar
Default Re: Side Marker Blinking fix? (CW-R hatchback)
yea they do they switch off when the others blink on. I personally like it a lot better.
Old Feb 9, 2007 | 09:50 PM
GQej1's Avatar
****. Now my left front corner light is dimmer and when I put the turn signal on it flashes way fast. The other side is fine though.
Old Feb 10, 2007 | 05:20 PM
GQej1's Avatar
help left front turn signal still fucked up.
Old Feb 10, 2007 | 08:29 PM
GQej1's Avatar
I replaced the light and it is still doing it help
Old Feb 10, 2007 | 08:32 PM
Nate047's Avatar
I have pix of this setup on my old EM1, I'll post one if you want.
I think they look fine as running lights... Mine were wired to turn on instead of the parking lights, with the city lights on as well... And they blinked alternating with the turn signals in the headlights...
Old Feb 10, 2007 | 08:34 PM
GQej1's Avatar
Default Re: Side Marker Blinking fix? (Nate047)
Yea I got them wired up just fine but now the left front corner light is dimmer and blinks way fast the left side is fine. Some one please help. Thanks.
Old Feb 10, 2007 | 08:37 PM
Nate047's Avatar
blown fuse most likely... check them out.
Old Feb 10, 2007 | 09:21 PM
GQej1's Avatar
i DID. The light still lights up and both the side markers light up its just the left front one is dimmer and when I turn on the left turn signal it blinks way fast. I checked the fuse and it seemed fine.
Old Feb 10, 2007 | 09:31 PM
Spoogen_1's Avatar
Keep them that way. Thats the way side markers are suppose to be. Having them on when your running lights are on looks lame imo.
Old Feb 11, 2007 | 10:45 AM
GQej1's Avatar
God damn it no one wants to help me with my tech problem all they want to do is tell me how to make a stock japanese car. expletive this. I'll figure it out myself.
civicSIfnatic
13
Aug 21, 2008 09:48 PM
NTCustoms
Oct 3, 2006 06:08 PM
Stunna MIKE
Jan 30, 2006 03:36 PM
EK Josh
Jul 26, 2005 09:38 AM
NUBREED
Apr 18, 2004 06:48 PM
