Clutch problem
I have a 93 del sol si and when i drive the car for a while it seems like the clutch doesn't disengage all the way because it is hard to put the car in all gears and every once in a while i can feel it grind just a little bit. When i let the car idle for a couple of minutes and drive the clutch feels normal and its easier to put it in all gears but gets worse after driving a while. i've bled the clutch line and the fluid was black (tried to get most of it out) but i was wondering what would cause this problem. any help is appreciated
Yes that could cause it. Make sure you get all the air out. And make sure that you're not leaking fluid anywhere. Also try searching, this seems to come up a lot on here.
BedDeMoN
Apr 1, 2009 03:42 PM
