Part Number Questions for Ls Block.
I just dropped off my Built Gsr head and my B18b1 Sleeved Block to be built. My builder told me that I need to buy a Few more parts to complete the build. So if you know the part numbers to these parts I need so I can Order them please post the info.
94 B18b1 Block:
Front & Rear Main Seals-------Got it
Oil Pan Gasket
OEM Main Bearings--------------Got it
OEM Rod Berings----------------Got it.
Before you ask. No I dont live by a Acura Dearlership.
Modified by fracas at 8:05 AM 2/10/2007
94 B18b1 Block:
Oil Pan Gasket
Assuming that you are using Oem Honda bearings, you will need the letter codes stamped into the block to determine the right bearing part numbers.
Are you replacing the oil pump? It should have a new front seal in the box.
A new oil pump is relatively cheap when compared to a blown motor.
Front main seal 91212-PR3-003 OIL SEAL (38X50X7.4)
Rear main seal 91214-PH1-004 OIL SEAL (80X100X10)
Yes I was going to replace the Oil Pump too.
Ok here is the run down of what I have.
Benson Sleeved Block
Eagle rods
Ross 9:3:1 84 mm
B20 Crank
So I need to get everything I need to go with my build. My builder is building my motor for me for Parts and doesnt want to spend money out of his pocket for stuff I need. So Im up to finding everything myself.
Eagle rods
Ross 9:3:1 84 mm
B20 Crank
You can obtain the parts from a Honda dealership as well. Look up the part numbers here
http://www.acuraparts247.com
or here
http://www.barancoacuraparts.com
Provide the part numbers to the Honda dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madness »</TD></TR><TR><TD CLASS="quote">Assuming that you are using Oem Honda bearings, you will need the letter codes stamped into the block to determine the right bearing part numbers.</TD></TR></TABLE>
or here
