random question
Old Feb 9, 2007 | 10:22 PM
pooltable13's Avatar
Default random question
i have two qestions.......1st is what is sleeveing ????i cant get a straight answer on this so many people say different things..........2nd what is knifeing the crank....i can get a staright answer on taht either
Old Feb 10, 2007 | 05:43 AM
j_bizach's Avatar
Default Re: random question (pooltable13)
Sleeving an engine is where they take a hallowed out cylinder of metal that is stronger that wat the block is made out of and put it place of the old cylinder wall. THis allows you to have a lighter aluminum block witht he strenght of a cast iron block. Most aluminum block come with sleeves but they are cheap and only ment to perform under stock conditions. Sleeving a block is absolutaly nessasary for high hp nubmer or boosting and engine.
Old Feb 10, 2007 | 05:51 AM
j_bizach's Avatar
Default Re: random question (j_bizach)
knife edging a crank is preaty much just lightening the crank, it also reduces drag because now insdead of slaping the oil in in pan it cuts through it and keeps weight away for the ppower reducing stress on your rods a nd pistons. It preaty much is something to do if your going to build your engine not suggested for stock or mild mods.
bunnyx
Jul 30, 2008 12:27 AM
RACING INTEGRATION
Honda S2000
Mar 17, 2008 07:47 PM
1G_DX_to_2G_Si
Oct 26, 2005 05:32 PM
b16 matt
Sep 27, 2004 02:33 PM
