break light going on/off
Old Feb 8, 2007 | 04:36 AM
kupras's Avatar
Default break light going on/off
I noticed when the car has been cold lately that the Brake light continues to stay on. The e-brake handle will be down and sometimes when its off and I start to drive while in first gear, it will go back on. Does anybody know what could be causing this and how to fix it?
Old Feb 8, 2007 | 05:21 AM
integra686's Avatar
Default Re: break light going on/off (kupras)
check your break fluid ./
Old Feb 8, 2007 | 05:37 AM
SuzukaBlueAP2's Avatar
Default Re: break light going on/off (integra686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra686 &raquo;</TD></TR><TR><TD CLASS="quote">check your break fluid ./</TD></TR></TABLE>
x2
Old Feb 8, 2007 | 06:39 AM
()()DC2's Avatar
i have the same problem.
Old Feb 8, 2007 | 06:42 AM
kupras's Avatar
Default Re: (()()DC2)
i will check the fluid levels its annoying how it comes on and off at different times especially in the cold
Old Feb 8, 2007 | 07:07 AM
numbnuts22715's Avatar
yep, its brake fluid...
this seems like a really common problem.. People need to start checkin their ****
Old Feb 8, 2007 | 07:13 AM
kupras's Avatar
Default Re: (numbnuts22715)
could any damage happen as a result lets say...if the fluid levels are low?
Old Feb 8, 2007 | 10:07 AM
kupras's Avatar
just one more quick question....could the light be that the pads are going its a 2001 LS, but never knew there was a sensor of any sort that told you when your pads were going
Old Feb 8, 2007 | 12:15 PM
nomotivdc4's Avatar
Default Re: (kupras)
there was actually a TSB by acura for this problem..usually its a sensor in the master cylinder so usually you can just open your master cylinder and the problem will go away for a while but what is actually wrong is that there is a white filter in the master cylinder and that usually gets clogged up and causes your brake light to go on..so just replace that..i think it was around $10
LunchboxZT
Sep 8, 2006 01:22 PM
.water
Jun 11, 2005 12:06 PM
jowy
Mar 14, 2005 05:52 PM
LSintegra
Apr 13, 2004 08:01 AM
vtec-izm
Aug 26, 2003 11:53 AM
