Went from 3rd to 2nd, now hardly can get into any gears and it grinds....
Old May 18, 2002 | 05:21 PM
CW-ITR-329's Avatar
Default Went from 3rd to 2nd, now hardly can get into any gears and it grinds....
Give me some suggestions on whats wrong. Thanks
Old May 18, 2002 | 05:27 PM
RedlineITR's Avatar
New User
Default Re: Went from 3rd to 2nd, now hardly can get into any gears and it grinds.... (CW-ITR-329)
synchros and throw out bearing probably
Old May 18, 2002 | 05:29 PM
ITR184's Avatar
What is your clutch doing? Try to bleed the clutch system and replace the fluid. I have had problems with it. If you can get into gear while it is parked see how far you can let out the clutch pedal before it engages. It should be at least 1/2- 3/4 if the clutch is engaging ok it might be the synchros. Good luck
Old May 18, 2002 | 05:30 PM
Warren's Avatar
Wrong-Way Wang
If you zinged it, I'll guess broken springs on the clutch disk, or busted pressure plate.
Warren
Old May 18, 2002 | 09:40 PM
nfn15037's Avatar
Default Re: Went from 3rd to 2nd, now hardly can get into any gears and it grinds.... (Warren)
Warren
Thats what im thinking....dont worry Ryan, itll be ok, keep your head up
Old May 30, 2002 | 03:37 PM
CW-ITR-329's Avatar
Default Re: Went from 3rd to 2nd, now hardly can get into any gears and it grinds.... (nfn15037)
Ended up being the pressure plate. I broke all the rivets that hold it together. What a relief! Ryan
fminusmic
14
Feb 1, 2022 05:07 PM
EG_LS
15
Sep 3, 2007 06:01 PM
Leo C
Jun 17, 2006 06:09 PM
KillaB18
Apr 21, 2005 08:43 PM
98_JiZZeR
Feb 17, 2004 09:07 AM
