2000 B18c5 into 96 dx wiring harness question
Old Feb 7, 2007 | 10:50 PM
96CivicBoostCoupe's Avatar
Default 2000 B18c5 into 96 dx wiring harness question
I swapped a B18C into my 2000 ITR and I'm swapping the B18c5 from my ITR into my 96 dx civic. Im using the stock ITR ecu. Can I use the harness from the ITR in my civic or do I need to get a different harness? If so which harness would be best or will work? I know I might need and OBD2a- OBD2B jumper. Any help would be appreciated thanks
Old Feb 7, 2007 | 10:52 PM
BlueIntegraBoy's Avatar
Default Re: 2000 B18c5 into 96 dx wiring harness question (96CivicBoostCoupe)
Why are you swapping in a B18C into your ITR?
Anyways, a 96-98 EX harness would be best and would be mostly plug and play.
Old Feb 8, 2007 | 05:35 AM
Default Re: 2000 B18c5 into 96 dx wiring harness question (BlueIntegraBoy)
just because I got a good deal on the B18C when the C5 had motor problems that im currently fixing, timing was good I guess and now Ill have a legit b18c5 in my civic that was titled to me. So the ex harness would be best, should I go with a obd2b from a 99-00 or a obd2a from a 96-98 with a jumper harness. I guess it wouldn't make a difference
Old Feb 8, 2007 | 09:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">just because I got a good deal on the B18C when the C5 had motor problems that im currently fixing, timing was good I guess and now Ill have a legit b18c5 in my civic that was titled to me. So the ex harness would be best, should I go with a obd2b from a 99-00 or a obd2a from a 96-98 with a jumper harness. I guess it wouldn't make a difference</TD></TR></TABLE>
96-98 with OBD2A --&gt; OBD2B jumper
Old Feb 9, 2007 | 09:04 AM
thats what Ill go with, thanks
Old Feb 9, 2007 | 11:18 AM
sicones's Avatar
you should be using a 96-98 ITR ECU, no conversion harness is needed
oosykooo
12
Feb 6, 2012 03:03 PM
BigRonDawg
Apr 24, 2006 06:04 AM
all4show97
Nov 6, 2005 01:44 PM
99'b16at
Oct 15, 2005 09:27 AM
tour de france turbo
Nov 21, 2002 02:53 PM
