Swaping a Z6 into my 1996 Dx Hatch EK
Old Feb 7, 2007 | 10:20 PM
D16z6BoostedEK's Avatar
Default Swaping a Z6 into my 1996 Dx Hatch EK
HELP please i was going to work one today and i was low on Oil and the motor went POOOOOOOOOOFF! so i have a friend that is selling me a Z6 for pretty cheap please send me useful diapharms i will b using a jumper hardness with a p28 ecu!
Old Feb 8, 2007 | 02:31 AM
P h i l's Avatar
Default Re: Swaping a Z6 into my 1996 Dx Hatch EK (JDrock86)
well u can do a couple things what i would do is order an obd2 to obd1 ecu conversion harness from boomslang ($100) and run a p28 ecu. then if the motor comes with the z6 distributer u need to take the obd1 igniter module out (the electrical thing that has the wires connected to it that goes to the 2 plugs wich then plugs into the engine harness.) then put the obd2 module from ur old distributer (it will have one big plug attached to it) into the z6 distributer, then ur dizzy will plug into ur engine harness. then just swap the motors. if u dont want to buy the conversion harness then just use a obd2 vtec ecu(p2p) but u will probably have a check engine for knock sensor or somthin like that
Cozmikk
Sep 21, 2017 12:33 AM
Cozmikk
Sep 19, 2017 05:07 AM
unautomobiled
Oct 7, 2014 02:37 AM
D16SiHatch
Jan 26, 2008 05:46 PM
Aquafina
Jun 8, 2007 02:18 PM
