how to pull code?
Old Feb 7, 2007 | 09:12 PM
Funkin Flux's Avatar
Default how to pull code?
Modified by Funkin Flux at 11:21 PM 2/19/2007
Old Feb 7, 2007 | 09:21 PM
yz125rider21's Avatar
count the red blinks on the ecu...be right in the middle....oh and its on passenger side under carpet...come back to us with codes...
Old Feb 7, 2007 | 09:24 PM
Modified by Funkin Flux at 11:22 PM 2/19/2007
Old Feb 7, 2007 | 09:34 PM
ok once is when you turn it on just to show it works then if it blinks once again thats code 1 then 7 times is code 7....
code 1 is o2 sensor
code 7 is TPS sensor (throttle position sensor)
Old Feb 7, 2007 | 09:36 PM
Old Feb 7, 2007 | 09:40 PM
ehh if you know what your doing then go for it with TPS i should get a diff throttble body cause you should never tamper with tps sensor....
Old Feb 7, 2007 | 09:43 PM
Old Feb 7, 2007 | 09:46 PM
25 bucks and like lifetime warranty :-)
h22acd5
Jan 21, 2009 07:32 AM
ALLshowNOgoLS
May 4, 2006 02:19 PM
kizner
Jan 29, 2006 09:39 AM
rasta420
43
Feb 16, 2004 12:39 AM
