irratic idle need help asap
Old May 18, 2002 | 04:47 PM
1stealthls's Avatar
Default irratic idle need help asap
im running a jdm b20 in my 95 g3 teg
and my idle jumps from 1000 to 1500 sometimes it will smooth out but then it idles at 1300 i know it isnt a vacum leak or intake manifold leak the car runs great but this vroom vroom crapo is annoying as hell please help me fix this problem
i need some
Old May 19, 2002 | 03:54 PM
1stealthls's Avatar
Default Re: irratic idle need help asap (Teken)
the idle screw is all the way in and it still does the same thing im thinking about putting the crv throttle body on and see if that does anything
this is starting to pi$$ me off
Old May 19, 2002 | 04:03 PM
SCsol's Avatar
Default Re: irratic idle need help asap (1stealthls)
check for codes then if none replace your coolant temp sensor (not the 1 wire one) that is most likly your problem
Old May 19, 2002 | 04:21 PM
1stealthls's Avatar
Default Re: irratic idle need help asap (lowsol)
no codes that i know of r u talking abot the sensor right below the distributer
Old May 21, 2002 | 06:11 PM
Doogie Howser's Avatar
it might be that you car will idle at 1000 then the fan will turn on and it will go up to 1500 then the fan goes of and it goes back to 1300
crxspoonb18c5
Jun 18, 2008 02:21 PM
JDM-ish
May 17, 2007 08:13 PM
OneFastGsr
Oct 8, 2003 08:30 AM
Vp Special K
Apr 4, 2003 09:14 PM
