fitment for GAB wheels?
ok so i have a set of authentic gabs. in the back, it has 15x_<---width not engraved in. i measured the wheel from side to side, and they are staggered. two are 15x8.5 +30 and two are 15x8 +35. weight is 590kg and bolt pattern is 5x114.3.
anyone seen this size of wheels before? anyone know if these wheels will fit a civic or integra with ONLY a 5 lug conversion? or are they too wide?
also, anybody know if the size of the wheels are perfect for an rsx(besides being 15'')?
thanks in advance!
thanks in advance!
for the 15x8.5 you will need to run negative camber, roll your fenders and mount skinny, stretched tires on there in order for it to fit and it will be a very bumpy ride for everyday and will throw off your speedometer if the sidewall/width is not suited for your particular car...also plan in getting a very stiff suspension to avoid rubbage. those wheels might be more suted for an ol skool fc rx7.
....and same thing for rsx.
the 15x8 might not be as bad but you will still need a lil effort for those to fit right
Suzukablue
Nov 22, 2012 08:33 AM
DeDonDeRosa
Honda Civic (2006 - 2015)
Nov 17, 2006 02:26 PM
