opinions on RDX guts into an ek??
not sure if this is in the right area but,
i was thinking about it and i know its been covered so many times, with the awd wagon
but do you think an EK hatchback with the complete 06' RDX sh-awd system and engine
work properly? what are your takes on the idea.
i just think it would be cool to see it done and how it preforms...i mean if money was no problem. I understand with money not being an issue you could go buy somthing else but id like to hear your opinions
Shortened awd integra Xi driveline, Xi carrier bearing, Nissan rear diff, modified ITR rear trailing arms with CR-V wheel bearings, ITR knuckles and CR-V wheel bearings up front, fuel cell to accomodate gas tank removal, shortened CR-V axles/shafts with RDX inners, motor mounts not lining up, wiring not working.... too much work, I would just put a lowering kit on the RDX, shave off the rear doors, slap some EK headlights on it, and chop the top, then call it a day.
