02+ Si prop. valve...
I know on 90+ integras they are 40/40, but what is the prop. valve on a 02+ civic si?
Reason Im asking... Im doing a brake upgrade on a 90 Integra sedan and I want to know if I should buy the prop. valve as well.
My future brake setup is as follows
Front - 94-95 Legend GS Dual Piston Calipers (and brackets), OEM Prelude VTEC 92-96 rotors (redrilled to 4x100)
Rear - EP3 Calipers (and brackets), OEM EP3 rotors (02-04, 4x100)
ITR master cylinder/booster, Russell SS Brake lines, Hawk Pads...
Any help would be appreciated..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skipbarber »</TD></TR><TR><TD CLASS="quote">02+ si's dont use proportioning valves.</TD></TR></TABLE>
Just as I thought, you're wrong.
See, here's a picture.
proportioning valves have 6 ports, not 4. 2 in from the master cylinder and 4 out to each caliper/cylinder. that picture is just a 4 way joint between the abs modulator and the rear brakes.
majestic:
459533 031 1 JOINT, FOUR-WAY
majestic:
slut
Oct 29, 2003 12:57 PM
