h22 vtec engagement at 5900rpm way to late?
Old Feb 7, 2007 | 03:21 PM
coreyhayman's Avatar
Default h22 vtec engagement at 5900rpm way to late?
my buddys 2.2 swapped civic running a chipped p28 is hitting vtec at 5900rpms, im telling him thats way to late as hes got to shift at 8000rpm. I told him to lower it to about 4900rpm and the car will be alot faster imo, what do you guys think, will it affect 1/4 times?
Old Feb 7, 2007 | 03:22 PM
turbociviccoupe's Avatar
Default Re: h22 vtec engagement at 5900rpm way to late? (coreyhayman)
yes thats a little late.
Old Feb 7, 2007 | 03:30 PM
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: h22 vtec engagement at 5900rpm way to late? (turbociviccoupe)
Redlines at 8000 and vtec engages at 5900? I say set it to about the GSR vtec engagement which is 4500-4700, I think. Anybody know for sure ?
But. Set it to about 4500 IMO!
Old Feb 7, 2007 | 03:32 PM
Default Re: h22 vtec engagement at 5900rpm way to late? (ViSioNxBoY)
5100 be good. thats what mines is set to.
Old Feb 7, 2007 | 03:45 PM
his cars quick but when vtec hits it really starts to fly, should hit just as hard down lower id think
Old Feb 8, 2007 | 06:06 AM
when do your guys secondarys open? and do you notice it more then hitting vtec?
Old Feb 8, 2007 | 06:11 AM
THC07's Avatar
Default Re: (coreyhayman)
you want the secoundaries to open at the same time as vtec, its good for 3lbs of tq. ive tested mine a bunch of times, 4700 is the sweet spot for my nearly stock setup.
Old Feb 8, 2007 | 06:16 AM
EJ ITO's Avatar
get a vtec controller and problem solved
Old Feb 8, 2007 | 06:39 AM
THC07's Avatar
Default Re: (EJ ITO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ ITO &raquo;</TD></TR><TR><TD CLASS="quote">get a vtec controller and problem solved </TD></TR></TABLE>
Gotcha, lol.
Modified by THC07 at 8:41 AM 2/8/2007
Old Feb 8, 2007 | 06:41 AM
deanBUG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ ITO &raquo;</TD></TR><TR><TD CLASS="quote">his cars quick but when vtec hits it really starts to fly, should hit just as hard down lower id think
isn't it that when vtec kicks in at a later rpm it gets more oil pressure therefore it "hits" harder?
Old Feb 8, 2007 | 06:44 AM
THC07's Avatar
Default Re: (deanBUG)
the "Ideal" vtec engaugement should not really be felt, you should only hear it. this is whats archived and said by the pros, i personally disagree.
where Hp and Tq curves cross is where vtec needs to be.
Old Feb 8, 2007 | 07:06 AM
EJ ITO's Avatar
Default Re: (THC07)
I know i'm just kidding didn't you see the
Old Feb 8, 2007 | 09:55 AM
doubledeucehatch's Avatar
You need to put it on a dyno and see when you power starts to drop off when you power without vtec starts to drop off is where you set you vtec to engage. I have a vtec controlle I will sell for 25 shipped if you want. I VTEC hit hard thats not good. When you look at you dyno print out it should be a steady increase not a peak.
Old Feb 14, 2007 | 09:33 PM
YABUDDY's Avatar
Default Re: (prelude252)
What kind of vtec controller is it?
DCFIVER
Jan 2, 2005 11:53 AM
93acclude
Aug 2, 2004 03:37 PM
pbizzlegsr
Jun 30, 2004 03:14 PM
Detroit
Jul 11, 2002 01:59 PM
accord5speed
May 9, 2002 08:09 AM
