Will a FPR increase my fuel comsumption?
I took my car to get it tunned several months ago. I was told I was burning lean. Could I just do my fuel pressure regulator and get a little more fuel into the mix or would that not change anything?
I was planning on doing the injectors later when I'm closer to finished with my project and knew which size I should get.
With out knowing what set-up you have or engine even, yes you can turn up your pressure as a small band-aid to cover you for a bit. Your on the right track look into injectors and tuning rather than crank up the fuel pressure.
midwesta
10
Aug 3, 2005 03:06 AM
saer
Jun 3, 2005 04:17 PM
zseeanz
Apr 5, 2004 07:48 AM
