Stuck coolant hose removal
Old Feb 7, 2007 | 10:27 AM
crisco_inferno's Avatar
Default Stuck coolant hose removal
I am in the process of removing my IACV on my OBD-0 B16 and I am having some trouble getting the two little coolant hoses off. I was able to remove the hose clamps with pliers but the hoses seem to be fused on there. I have big hands so it's hard to get a good grip on them.
Does anybody know any tips/tricks for getting these off easily? Any help is appreciated.
Old Feb 7, 2007 | 10:28 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Stuck coolant hose removal (crisco_inferno)
Just cut them, they probably need to be replaced anyways. Just get some bulk hose from an auto parts store to make new ones.
Old Feb 7, 2007 | 11:43 AM
n3h3bkau's Avatar
Get a pair of pliers and grab the base thats around the "nipple" squeeze and twist. It'll brake the hose loose.
Old Feb 7, 2007 | 11:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Stuck coolant hose removal (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Just cut them, they probably need to be replaced anyways. Just get some bulk hose from an auto parts store to make new ones.</TD></TR></TABLE>
Do like wizco said, split the hose lengthwise from it's end to the full length of the barb it's on, then peel it back like a Banana. Get a few feet of some bulk hose (either 1/4" or 3/8") and replace. I like to keep a few feet of 1/4", 3/8", and 5/8" coolant rated hose in my shop, along with some vacuum hose and 1/4" ID fuel hose. You never know when you're going to need it, and it's cheap!
Old Feb 7, 2007 | 11:58 AM
89efDUSTY's Avatar
Default Re: Stuck coolant hose removal (DaX)
Try to twist them and push it...it should break the seal then try pulling off while twisting in the opposite direction. The pushing in and twist does it most the time for me, but truely you should get new hoses because they may no properly reseal
glagola1's Avatar
Default Re: (n3h3bkau)
I've had tons of luck with the twisting with plyers method. It'll save you from another freaking trip to autodrone if you don't kill the hose.
mullenium
Oct 12, 2008 03:08 PM
PatrickGSR94
Aug 12, 2008 09:52 AM
Tizight
Nov 19, 2006 02:25 PM
92civeg
Dec 16, 2003 02:39 PM
Andrew 825SM
Oct 28, 2002 02:31 PM
