Serious Question! HELP Regarding Shocks (PICS INSIDE)
Old Feb 7, 2007 | 09:40 AM
Tech-Nics's Avatar
Default Serious Question! HELP Regarding Shocks (PICS INSIDE)
ok i was under my car draining out old coolent when i noticed somthing.
(mind you - i dont go under my car much)
now that whole piece where the spring and the shock is it can move around freely, i can jiggle it around alot (very loose) and it looks horrible, now its been a long time since i looked there but the other side is alit more tight in place but has little slack aswell...well are my shocks blown? and springs too.....
Old Feb 7, 2007 | 09:54 AM
walker111's Avatar
Default Re: Serious Question! HELP Regarding Shocks (Tech-Nics)
You had your car jacked up? If the springs werent compressed, that is normal for a fairly generic setup.
Old Feb 7, 2007 | 10:05 AM
TheMuffinMan's Avatar
He knows where you live!
Yep, if you were jacked up that's how mine are as well
Old Feb 7, 2007 | 10:09 AM
Tech-Nics's Avatar
but even the whole silver piece moves around too...not just the springs....is that still normal??? and the passenger side was alot tighter in place.
Old Feb 7, 2007 | 12:05 PM
iam7head's Avatar
no and no
the damper looks blown, the bump stop looks like it's been sat on by an elephant and that's what happen when you use pos coilover on oem shocks
Old Feb 7, 2007 | 12:42 PM
timmy0tool's Avatar
the silver part is called the sleeves. they should be snug against the shock absorbers. they are held in by rubber spacers, usually, but what you have are generic coilovers so they might not have them. they can still work on the car but when you hit large bumps on the road, being loose it can shift and change position; just like the upper part of the spring.
i say get some regular lowering spings.
EM2junkIE
Honda Civic (2001 - 2005)
Sep 18, 2008 10:12 PM
FalkenSiR
Suspension & Brakes
Nov 29, 2005 03:06 PM
bearboy80
Apr 3, 2003 10:10 AM
XxSOHCDriVerxX
13
Jan 11, 2003 09:36 AM
Stage5Lude
Jul 1, 2001 09:57 AM
