Oil in throttle body/IM?
Old Feb 6, 2007 | 07:08 PM
boomersz's Avatar
Default Oil in throttle body/IM?
bought a gsr motor awhile ago and just forgot to ask. not sure if it came out of there or it just got there when ever he sprayed down the motor with water.
edit-just checked and there's only a little bit of oil opening the throttle body.
what would oil in the throttle body or intake manifold mean?
Modified by logiT at 10:29 PM 2/6/2007
Old Feb 6, 2007 | 07:47 PM
EG2Driver's Avatar
Default Re: Oil in throttle body/IM? (logiT)
If you look at your intake, it has a tube going from the valve cover to it. Oil might find its way in there and into the intake. I know mine on my B16 has black hunk all over it, and i'll take it off and clean it for sure.
Old Feb 6, 2007 | 07:58 PM
wernhersey's Avatar
That hose that goes from the valve cover to the intake is like a PCV (positive crankcase ventilation). Honda uses a fixed orfice rather than a valve. This allows unburnt crankcase gases back into the combustion chamber. It is used as an emission control. Oil will build up in the TB but it is normal, cleaning the TB once in awhile is a great idea. Just for a little FYI removing the hose and replacing it with a filter will keep the oil from building up in the TB but it will make your car produce worse emissions. The hydrocarbons and carbonoxides will sky rocket.
Old Feb 6, 2007 | 08:19 PM
boomersz's Avatar
Default Re: Oil in throttle body/IM? (wernhersey)
thanks guys. there's only a little in there. the rest through the IM looks real clean. just some on the TB
JigsN Joints
May 20, 2011 05:08 AM
so simple
May 11, 2010 11:49 PM
so simple
May 1, 2010 05:32 PM
slob20ef
21
Apr 28, 2009 08:28 AM
2stockrocketz
Apr 13, 2004 09:22 PM
