Do the Azenis 205/50/15 rub at full lock on stock ITR rims??
Old May 18, 2002 | 12:18 PM
hooptie157's Avatar
Default Do the Azenis 205/50/15 rub at full lock on stock ITR rims??
I have the 205/50/15 on my stock rims and at full lock they feel like thy rub. Does anyone else have this problem?? Could anything else be the problem??
Old May 18, 2002 | 12:36 PM
slash00R's Avatar
New User
Default Re: Do the Azenis 205/50/15 rub at full lock on stock ITR rims?? (hooptie157)
You could have a midget stuck in your wheel well I guess
Old May 18, 2002 | 12:51 PM
acuracing's Avatar
Don't know why it would rub. Is your car lowered more than normal?
Old May 18, 2002 | 02:20 PM
RTW DC2R's Avatar
Default Re: Do the Azenis 205/50/15 rub at full lock on stock ITR rims?? (acuracing)
I think my 205/50/15 Kumhos rub at full lock, same size, but different tire. but my car has been in an accident so it could be related to that.
Old May 18, 2002 | 02:40 PM
Bob#455's Avatar
Stock suspension here, and no rubbing.
Old May 18, 2002 | 03:39 PM
Chui's Avatar
From: Somewhere in the MidWest..., The MidWest..., USA
Default Re: Do the Azenis 205/50/15 rub at full lock on stock ITR rims?? (Bob#455)
Hate to push the "Azenis thing" but I'm up for new tires immediately and I was considering the Azenis as well as the Potenza S03s, obviously. At $63 to $70 per corner the Azenis seem like a deal. By looking at them they would not be ideal in the rain, but with 12k hard street miles on the RE010s that are currently mounted anything, and I do mean anything, is better than what I'm currently running. I have 15x7 Kosei K-1 Racing wheels, stock suspension. I've read how much wider the 205 Azenis are and how they are unresponsive on 15x6 wheels. I figure they'd be fine on 15x7s. My question is how well do they last. I'm committed to replacing my tires every season and I put approximately 12k miles per "season" with the car.
As for the Bridgestone Potenza S03 are concerned I've heard/read here that they are "much wider than a similarly sized tire" as well. If that's the case any recommendations of using a 195/50 S03 on a 7" wheel? Thanks, guys.
Old May 18, 2002 | 04:31 PM
Renegade's Avatar
I'm lowered 2' and they rub, I can see where the y tire rubs when I take off the wheel.
Old May 18, 2002 | 05:15 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Yes & No! On a flat surface taking the hardest tightest turns, No. The same tight turn up a driveway at about 12-15mph, Yes. But they didn't rub on the fender, they rubed on the inside motor splash guard, Chewed it up just a little with no damage to the tire. Hope this helps.
P.S. Stock hight!
[Modified by 01PYTypeR#1140, 9:16 PM 5/18/2002]
Old May 18, 2002 | 05:45 PM
hooptie157's Avatar
Default Re: Do the Azenis 205/50/15 rub at full lock on stock ITR rims?? (01PYTypeR#1140)
P.S. Stock hight!
Yep the same thing here, only rubs sometimes at certain MPH. I was also thinking about getting spoon springs. Would 205-50-15 azenis's and spoon springs be bad as hell with rubbing??
Old May 18, 2002 | 10:18 PM
nsxtcjr's Avatar
New User
Default Re: Do the Azenis 205/50/15 rub at full lock on stock ITR rims?? (98401R)
Of course they will rub if you lower the car two feet. Heck, to lower the car two feet, you probably had to dig a hole under the entire car because the car body is normally about six inches above the pavement, so you had to dig a hole 18 inches deep to bury the car in to lower it two feet.
Old May 19, 2002 | 07:41 PM
TypeRTexan's Avatar
205/50/15 Toyo RA1s on stock ITR rims and suspension. No rubbing.
TypeR1558
Jan 1, 2003 01:19 PM
Chaze*R
Jul 23, 2002 10:33 PM
snowman
Jan 26, 2002 11:59 AM
jonsteR
Dec 12, 2001 01:46 PM
99ls
Jul 13, 2001 06:22 PM
