N/A catch cans, why do some have breathers?
Old Feb 6, 2007 | 04:57 PM
YoungKadafi's Avatar
Default N/A catch cans, why do some have breathers?
i thought the breathers are just for FI? how come i see some vented catch cans on NA setups?
Wouldnt this create a crazy vaccumm leak? unless there is a check valve installed between the can and the filter
also, would connecting the valve cover vent (the one that connects to the intake arm) To the catch can, and having all that route back into the IM, have any benifits? I would just plug the hole up on the intake arm.
Also have the catch can line, that runs into the IM, branch with the cruise control vaccumm line, to help pull additional air in, yay? or nay? just want the most efficient setup, and i dont have cruise control, that is blocked off....no emmissions here either
Old Feb 6, 2007 | 05:32 PM
RagingAngel's Avatar
Default Re: N/A catch cans, why do some have breathers? (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">i thought the breathers are just for FI? how come i see some vented catch cans on NA setups?
This allows it to vent into the atmosphere, so no more oily residue gets sucked back into the T-body/IM. The vac. leak only occurs if you have an open vac. source which is probably the IM in this case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
This setup is good if you are running on the street where emissions are a concern. It would allow oily air to be filtered a second time after the OEM oil separator box (blackbox) on the back of the block.
Also have the catch can line, that runs into the IM, branch with the cruise control vaccumm line, to help pull additional air in, yay? or nay? just want the most efficient setup, and i dont have cruise control, that is blocked off....no emissions here either
No.
Old Feb 6, 2007 | 05:57 PM
Default Re: N/A catch cans, why do some have breathers? (RagingAngel)
hmmm, thats wierd, because when i put a vented can, it got a huge vac leak, all the oil then got sucked into the IM, i was like WTF!!!! how do people do this!@
Old Feb 6, 2007 | 05:59 PM
DonF's Avatar
Just run a turbo, then you will be OK.
Old Feb 6, 2007 | 06:16 PM
mgags7's Avatar
Default Re: N/A catch cans, why do some have breathers? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Just run a turbo, then you will be OK.</TD></TR></TABLE>
Yea I second that notion. Allmotor is for slowboys.
Old Feb 6, 2007 | 06:33 PM
AllMTRWH0R3's Avatar
Default Re: N/A catch cans, why do some have breathers? (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Yea I second that notion. Allmotor is for slowboys.</TD></TR></TABLE>that's almost a classic quote
Old Feb 6, 2007 | 06:38 PM
wait, i posted this up in all motor? and the turbo boys show up? hmmmm....so the filtered cans are only for FI?
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, thats wierd, because when i put a vented can, it got a huge vac leak, all the oil then got sucked into the IM, i was like WTF!!!! how do people do this!@</TD></TR></TABLE>
Maybe you hooked it up wrong?
Follow these instructions and you should be fine. I did this with a modified Greddy can and its good.
https://honda-tech.com/zerothread?id=1199935
Old Feb 6, 2007 | 06:40 PM
mgags7's Avatar
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">wait, i posted this up in all motor? and the turbo boys show up? hmmmm....so the filtered cans are only for FI?</TD></TR></TABLE>
lol
TwoFacedCustoms
Oct 15, 2010 08:43 AM
Happy Gilmore
Nov 7, 2008 08:15 AM
JBirch_97Prelude
May 6, 2007 04:07 PM
AccordRacing
May 27, 2005 05:42 AM
JICEK9
Nov 25, 2003 05:55 AM
