Need help taking off front bumper & side skirts
I need help taking off the front bumper and side skirts from a 97 Integra.
Does anyone have helms manual or pics that show how to take off front bumper and side skirts?
I see a few visible bolts that I can screw off, but I have no clue where the hidden ones are.
here you go. its a guide for installing a grill but it shows how to take off the front bumper. goodluck
http://grillcraft.com/installs/insta...iew&install=61
Wow, that sure clears things up. Thanx bro!
I hope it's the same on the 94-97 bumpers.
EDIT: I just found out how to remove side skirts.
[Modified by Calavera, 1:48 PM 5/18/2002]
i think the sideskirts are just like 3 or 4 screws. and i think after you take the screws out you push the skirts towards the front of the car. but im not sure.
and heres the one for the 94-97. have fun
http://grillcraft.com/installs/insta...view&install=1
courtesy of wingswest. the pictures suck, but if it works...
http://www.wingswest.com/bodykits/94...A_R.S.TYP1.pdf
[edit] opps, just read throught the instructions and found out you dont take off the stock skirts[edit]
[Modified by Mt3c, 2:39 PM 5/18/2002]
Thanx for the info.
However, I am stuck on step 6.
Does anyone have a helms manual that show exactly where the screws are? The pic is kinda dark and I'm a noob so I can't tell ****.
Ah..well after 3 hours of frustration and stress, I was able to put on the new fender. Putting the front bumper back on was kind of annoying.
I broke a few clips that hold the screws in place though.
hehehe. Don't get your hopes up, all I was trying to do was replace the damaged fender caused by an accident a few weeks ago.
In order to take off the fender it was neccessary to remove the side skirts and front bumper. Sorry mang.
But I'll post pics as soon as I get my lip and may be rims.
the side skirts are very easy to take off....get underneath and you will see about 6 or more black plastic screws. Unscrew all of them, but do not put any pressure on the screw or will just end up spinning and spinning. It may do that but keep unscrewing and eventually it will come lose/out. Once all the screws on the bottom are taken out, i believe you push the side skirts forward towards the front of the car...the skirts should slide out of its clips. Hope that helps some
these diagrams and the above post should be more than sufficient. good luck bro. i just took mine off a couple hours ago
[Modified by alphadrewdc2, 12:48 AM 5/20/2002]
Thanx for the instructions!
But you didn't have to post them twice. hehe I was going back and forth trying to see if there was a difference.
AdRoz
Dec 27, 2007 05:50 PM
1_QWIK_HF_CRX
Jun 28, 2005 11:52 AM
GreenMachineRex
Apr 21, 2005 04:12 PM
