B16 redline?
Old May 18, 2002 | 11:57 AM
si foo's Avatar
Default B16 redline?
Hey guys my B16 redlines at 7k with the check engine light on??????Any idea why? Reading code one (oxgyen contents)
Old May 18, 2002 | 11:59 AM
mafioso102's Avatar
New User
Default Re: B16 redline? (si foo)
mine would do the same. it read a code 2 though, i changed the oxygen sensor and everything was alright.
Old May 18, 2002 | 12:01 PM
EP3_05's Avatar
When the CEL is on the ecu drops the revlimit. Fix the code and it should be fine.
Old May 18, 2002 | 01:20 PM
si foo's Avatar
Default Re: B16 redline? (mafioso102)
where is the oxgyen sensor located at guys?
Old May 18, 2002 | 01:24 PM
rsxturbo's Avatar
wow man... you need to get a crx manual and just readdd and readdd and readdd. on the header there are two, that is the thing coming off the head with four tubes ;x
Old May 18, 2002 | 06:46 PM
brad.'s Avatar
Default Re: B16 redline? (rsxturbo)
hahahahahahahahaha
Old May 19, 2002 | 04:04 AM
Giuseppe's Avatar
Default Re: B16 redline? ([626]JDM-b16a-EF9)
i still say automatic ECU.!!!
Old May 19, 2002 | 08:03 AM
puffinrice's Avatar
Default Re: B16 redline? (Giuseppe)
well it doesn't matter if the engine light is on, it is at 7 becuase you v-tech isn't most likely activating. i had the same prob, by v-tech wasn't working, but once i got it to work, it went all the way to 8200 so i would just the plugs going to the v-tech selenoid, but if you v-tech is working and it is till going to 7 grand, do what the engine code is telling you to do. well do that either way
liljohn850
May 23, 2009 01:56 PM
jchrm80
Jan 30, 2008 09:42 PM
teler86
Nov 30, 2004 12:08 PM
E-AT_me
Jul 15, 2002 08:43 PM
