WTF wires.. They're all over.. And unplugged.. *pics*
found these by the feet area..
can anyone tell me what they go to? Im not TOO worried, the car runs fine, but I'd like to know for piece of mind.
yes yellow is the srs. but there are always random harnesses not plugged in on every car. my friends eclipse had them all over. no worries if everything runs fine and your accessories work.
check your car at startup. if your SRS light comes on and goes off you should be fine. if i doesnt come on, get the bulb and see if it just stays on....if so you have a major problem as your SRS system will not work. Or you can just remove the airbag systems, save some weight, make some money and put a new steering wheel setup in that doesn't require airbags. less your state inspection requires it
Well, see, I have a 96. I SHOULD have the el glow gauges with an automatic P R N D setup.. but, when the motor was swapped the guy put in a 93 JDM cluster with no SRS light space, just a 4WS spot.. So I really have no idea..
but as for the solution, I really dont care either way if there are airbags working or not, as long as they wont shoot out on me at random if I kick a wire or something by accident. I'd just rather assume sell the steering wheel with the cruise control part on there and buy a racing wheel.
It could be the speakers on that side of the dash or the door. The twisted wires are usually for the speakers. Grab a manual and check if you're worried.
claymonthug
Feb 14, 2010 06:17 PM
