1992 integra muffler question
I've got a 92 teg with a custom exhaust system on it. Car is turbocharged with 3" piping, a hi flow cat and NO resonator. Its loud at all times, high and low rpms. Can anyone suggest something that i could get to fit on this car since not many company's make one for it. My aim is quieter without much HP loss
Adding a resonator would be a good start.
Two main types Look iside to tell the difference:
one with scallops on the inside that protrude out (spiral shape usually) and grab the air.
The other with drilled holes only and a smoother looking flow.
The second one looses less power and would be the one to choose. May be tougher to find in three inch though.
KC
KC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_bizach »</TD></TR><TR><TD CLASS="quote">sorry but you doomed f/i will always be loud. try putting a resonator back in, thats wat ther made for.</TD></TR></TABLE>
On the contrary, the turbo quiets exhaust noise quite a bit.
You don't mention what kind of muffler you're currently running, but if you pair a Magnaflow muffler (chambered would reduce noise more, at the expense of some flow) with a large resonator, you should have a decent reduction in volume. Keep in mind though that you'll be running a 3" performance system, so it's never going to sound like a stock setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
You don't mention what kind of muffler you're currently running, but if you pair a Magnaflow muffler (chambered would reduce noise more, at the expense of some flow) with a large resonator, you should have a decent reduction in volume. Keep in mind though that you'll be running a 3" performance system, so it's never going to sound like a stock setup. </TD></TR></TABLE>
The only route I can see for what you want is to get a resonator welded into your current exhaust.
