Oil pump question
I have a LsVtec motor and i am not getting enough oil pressure off of the back of the block...could I run my vtec line stright from the big plug on the oil pump? should using that spot increase/stabilize my pressure and would running a bigger line that allows for more flow help too? just lemme know thanks...
k
k
jdm b16 oil pump(i dont think jdm v. usdm should make a difference) the pump came off the same motor that my head came from and it was in good shape so I assume the pump should be in good shape too...
[Modified by lsvtec42, 5:22 PM 5/18/2002]
