Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Frozen Amp????
Old Feb 6, 2007 | 08:37 AM
The Answer's Avatar
Default Frozen Amp???
Okay, so over the past week, week and a half, we've had some seriously cold weather in the northern suburbs of Chicago. We're talking in the negative almost everyday.
Now I know this may sound dumb but I really think that my amp may have frozen over from being out in the cold.... I'm not sure, been too cold to check it out. But I couldn't imagine it being any faulty wiring, I know the ground is good and so it the power connection to the battery.
But I was driving one day listening to the radio, and the subs were working fine, all of a sudden, the song stops on the radio, goes to commercial break, comes back, music goes back on, and the subs stop working.
-No I wasn't pounding the crap out of the subs, settings were as minimal as they could get.
Any idea what it could be?
Old Feb 6, 2007 | 08:50 AM
SickSpd06Si's Avatar
Default Re: Frozen Amp??? (elklodgeezra)
did you check the fuses. Is the amp lighting up. Probly just a fuse in the amp. Maybe the inline fuse went. (90 percent of the time that's the problem with an amp)
Old Feb 6, 2007 | 09:02 AM
Michael Bolton's Avatar
Default Re: Frozen Amp??? (SickSpd06Si)
whats your set up?
Old Feb 6, 2007 | 09:04 AM
The Answer's Avatar
1000 watt kenwood, with 2 500watt kenwood subs, but yeah I'll check all the fuses today after I get off work, I knew I would have to do it eventually, but I don't see why the fuses would spontaneously go?
Edit: Actually, I think I'll go check them in about an hour, I have nothing better to do plus I wanna get to the bottom of this.
Old Feb 6, 2007 | 10:28 AM
RICO_'s Avatar
NO MERCY!
Default Re: (elklodgeezra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elklodgeezra &raquo;</TD></TR><TR><TD CLASS="quote">1000 watt kenwood, with 2 500watt kenwood subs, </TD></TR></TABLE>
Weaksauce! You're car is trying to tell you something. .
j/k. Hope everything gets fixed bro.
Old Feb 6, 2007 | 10:29 AM
The Answer's Avatar
Yeah thanks, and I didn't want anything too overbearing, just something better than stock. Hopefully it's nothing, maybe the ground came loose *doubtful", but we'll see, I'm gonna go check it out here in about 15 minutes and report back.
Old Feb 6, 2007 | 11:03 AM
The Answer's Avatar
Okay, turns out I'm an idiot, after checking the fuse on the amp, I notice there's a wire disconnected.......
Old Feb 6, 2007 | 11:57 AM
jonebone's Avatar
Video Game Collector
Yeah thats almost always the case... Also don't forget about the fuse under the hood where it connects to the battery. I've seen those blow a few times as well.
Old Feb 6, 2007 | 12:09 PM
The Answer's Avatar
Yeah, I was going to check that, but then I found the ground unplugged, still trying to figure out with the f* happened.
Old Feb 6, 2007 | 01:12 PM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elklodgeezra &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I was going to check that, but then I found the ground unplugged, still trying to figure out with the f* happened.</TD></TR></TABLE>
:: sighs ::
Old Feb 7, 2007 | 07:15 AM
FBPSidan's Avatar
Default Re: (RICO_)
is ur amp on the box? if so does the box slide around when you drive? ive seen that happen a million times when people come in telling me that...
Old Feb 7, 2007 | 07:30 AM
The Answer's Avatar
Yeah amp is attatched to the box, and it slides around a little bit, I have braces for the box, but I've neglected to mount them.
Old Feb 11, 2007 | 06:05 PM
axtran's Avatar
perhaps you should mount them, and maybe secure the ground a little bit better good luck to ya! and good job on the problem find and the solution
Day_Walker
Audio / Security / Video
Apr 24, 2009 06:45 AM
PearlBlueType-S
Mar 24, 2006 03:37 PM
mulletov
Aug 6, 2005 07:59 PM
TurBoTeG
Oct 26, 2002 10:32 PM
beastgsr
May 28, 2002 12:10 AM
