Car doesnt start but works when push start?
Old Feb 6, 2007 | 07:08 AM
k_lude's Avatar
Default Car doesnt start but works when push start?
my lil bros car doesnt start up sometimes mostly when the engine is hot...it then needs to be pushed to be started with first gear in so wat can be the problem?
Old Feb 6, 2007 | 07:42 AM
skunked's Avatar
Default Re: Car doesnt start but works when push start? (k_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">my lil bros car doesnt start up sometimes mostly when the engine is hot...it then needs to be pushed to be started with first gear in so wat can be the problem?</TD></TR></TABLE>
most likely the starter however make sure the battery connections and grounds are clean and tight.
Old Feb 6, 2007 | 10:55 AM
k_lude's Avatar
Default Re: Car doesnt start but works when push start? (skunked)
i was thinking that too...but when he had the starter tested with a volt tester thing it was shooting up but it took a while for the battery...also when this happens when your inside the lights tend to die out of color a little while trying to start the car...so were looking towards battery but can i be starter?
Old Feb 6, 2007 | 11:00 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking that too...but when he had the starter tested with a volt tester thing it was shooting up but it took a while for the battery...also when this happens when your inside the lights tend to die out of color a little while trying to start the car...so were looking towards battery but can i be starter?</TD></TR></TABLE>
put a voltage meter accross the battery terminals, if it drops allot then it could be the battery. Batteries usually tend to start failing when it's cold, not hot therefore I still think it's loose battery terminals or bad starter.
The interior lights should dim a little when the starter is cranking.
Old Feb 6, 2007 | 12:01 PM
ADerks12's Avatar
couldn't you just take it to an auto store and get them to test the batter? i know thats what we did when we had starting problems.
pepper
Sep 21, 2007 07:27 PM
kiklo16
Aug 3, 2007 06:46 AM
hon da top
27
Apr 1, 2007 06:24 PM
eg686
Aug 22, 2005 10:16 PM
ILOVEGIRLS
Sep 5, 2003 12:03 AM
