corner lights
Old Feb 6, 2007 | 04:27 AM
94eh2's Avatar
Default corner lights
alright i have a problem with my corner lights on my eg hatch...when i put my lights on they dont work but if i put my blinker they do work ..whats the pproblem?
Old Feb 6, 2007 | 04:40 AM
BLUIZE256's Avatar
Default Re: corner lights (305accord)
both corner's or just one?
cuz i had that prob. once but it was only with one corner and when i changed the bulb it started working fine again. .
Old Feb 6, 2007 | 05:01 AM
94eh2's Avatar
Default Re: corner lights (BLUIZE256)
no its with both of them
Old Feb 6, 2007 | 06:05 AM
'94civic b16's Avatar
its the way you have them wired, sounds like you wired them so they only blink with the turn signal.
Old Feb 6, 2007 | 06:54 AM
ek4_b16a's Avatar
Default Re: corner lights ('94civic b16)
check your fuses
Old Feb 6, 2007 | 07:04 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’94civic b16 &raquo;</TD></TR><TR><TD CLASS="quote">its the way you have them wired, sounds like you wired them so they only blink with the turn signal.</TD></TR></TABLE>
huh? what the hell? why would he have to wire is corner lights for? they come already wired straight from the factory. read the post again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord &raquo;</TD></TR><TR><TD CLASS="quote">alright i have a problem with my corner lights on my eg hatch...when i put my lights on they dont work but if i put my blinker they do work ..whats the pproblem?</TD></TR></TABLE>
OP, the question i have for you is, do you have anything tapped into your wires?
are your taillights out too?
Old Feb 6, 2007 | 08:08 AM
92EG8's Avatar
305accord is a friend this is a little more info
He has them tapped into his sidemarkers but even before the sidemarkers his front coners never worked with the vehicles headlights on (2 clicks or the corners 1 click of the Headlight switch). All fuses are checked as well.
Old Feb 6, 2007 | 08:11 AM
philosofy1's Avatar
Default Re: (92EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 &raquo;</TD></TR><TR><TD CLASS="quote">305accord is a friend this is a little more info
He has them tapped into his sidemarkers but even before the sidemarkers his front coners never worked with the vehicles headlights on (2 clicks or the corners 1 click of the Headlight switch). All fuses are checked as well.</TD></TR></TABLE>
if that's the case i would grab a voltage meter and start troubleshooting. can be a break in the wiring, a faulty relay, or the switch itself.
are the taillights operational?
Old Feb 6, 2007 | 08:49 AM
verycleanhatch's Avatar
i have mine wired like that on purpose.
Old Feb 6, 2007 | 09:41 AM
92EG8's Avatar
Yeah its is the JDM way to have ur headlights like that but i like them when they are on. The tail lights as i said do work. Even hazards work in the back lights but not in the front
91civicsikid
Jul 24, 2008 06:27 PM
wesley_925
Lighting
10
Jul 5, 2008 06:34 PM
my_gsr_teg
Apr 27, 2008 03:09 PM
Spec R
Feb 17, 2006 10:48 AM
roc
Sep 7, 2005 05:27 PM
